Forum: ARM programming with GCC/GNU tools SPI Accelerometer
von Mike J. (cobra050)
I'm trying to get the ADIS16003 to work with my AT91SAM7S256-EK
my SPI Init looks like this:
void SPI_Init(void)
  AT91F_PMC_EnablePeriphClock ( AT91C_BASE_PMC, 1 << AT91C_ID_SPI ) ;
    AT91F_SPI_Reset     (AT91C_BASE_SPI);
    AT91F_SPI_Enable    (AT91C_BASE_SPI);
    AT91F_SPI_CfgMode   (AT91C_BASE_SPI,
               AT91C_SPI_MSTR |
               SPI_FIX_SLCT |
             SPI_CS_DIRECT |
             SPI_MODE_FAULT_DS |
             SPI_LOCAL_LOOP_DS |
             SPI_FIXED_CS_0);
    AT91F_SPI_CfgCs     (AT91C_BASE_SPI, 0,
               SPI_SCK_IDLE_LOW |
             SPI_SCK_SAMPLE_RISING |
             SPI_CS_HIGH_AFTR_TRANS |
             SPI_16_BITS_PER_TRANS |
            (4*SPI_SCK_DIV_FACTOR));
    AT91F_PIO_CfgPeriph( AT91C_BASE_PIOA,
    ((unsigned int) AT91C_PA13_MOSI    ) |
    ((unsigned int) AT91C_PA14_SPCK    ) |
    ((unsigned int) AT91C_PA11_NPCS0   ) |
    ((unsigned int) AT91C_PA12_MISO    ),
        0 );
AND here are my read and write functions:
int SPI_Send(char character, unsigned int cs_number, int last_xfer)
  unsigned int value_for_cs;
  value_for_cs = (~(1 << cs_number)) & 0xF; //Place a zero amonga 4 ONEs
number
  // Wait for transmit data register to become available
  while ( !(AT91C_BASE_SPI->SPI_SR & AT91C_SPI_TDRE) );
  if (last_xfer)
    AT91C_BASE_SPI->SPI_TDR = (value_for_cs << 16) | character |
AT91C_SPI_LASTXFER; // CS# | Character | Last xfer
  else
    AT91C_BASE_SPI->SPI_TDR = (value_for_cs << 16) | character; // CS#
|Character
  return 0;
int SPI_Read()
  int rxbyte;
  while ( !(AT91C_BASE_SPI->SPI_SR & AT91C_SPI_RDRF) );
  rxbyte = AT91C_BASE_SPI->SPI_RDR & 0xff;
  return rxbyte;
I do the following but get the same value for rxbyte every time
SPI_Send(4,0,0); //tells ADIS to read x-axis
rxbyte=SPI_Read();
any help is appreciated
von Edwinn S. (egwyn)
Hi, you can get work whit adis ??, I'm trying but with HC08, but  not to
obtain an answer of adis, your already you are able to obtain some
measurement?. please any help.
