Forum: ARM programming with GCC/GNU tools interrupt attribute
von outer_space (Guest)
Why doesnt the gcc interrupt attribute work?  Is anyone working on
fixing it?
von Martin Thomas (Guest)
> fixing it?
The attribute works if the code is compiled in "arm-only"-mode. There
are known issues when using the attribute together with interwork, maybe
just when optimization is enabled. The problems is known and there are
patches in the gcc-bugzilla. As far as I know the patches are not
included in gcc 4.1.1. The gcc-bugzilla provides further information.
IRC the topic has been discussed in the GNUARM-yahoo-group and in this
forum some time ago. I have mentioned some "workarounds" an this forum
some days ago.
This forum is not the best place for a question about the state of the
gcc-development (better: gcc mailing-list).
Martin Thomas
von Pete G. (pgasper)
Martin Thomas wrote:
>> fixing it?
> some days ago.
> Martin Thomas
What is the purpose of the attribute? Some code uses it, some doesn't.
For example the compiler should generate instructions to "adjust" the
return-address when this attribute is used. See ARM technical manual
about return-addresses of exceptions.
Martin Thomas
von Andy X. (andy0815)
>> fixing it?
> some days ago.
> Martin Thomas
The problem is still there. Any chance to use
__attribute__((interrupt("irq")) without workarounds? It is quite
annoying took me a whole day to figure out that wrong code is generated.
