Forum: ARM programming with GCC/GNU tools WinARM and STR71x
von Jeremy M. (jmaccelari)
I have tried to get the following project to compile and work on an
Olimex STR-P711 with gcc. It's the STR71xLibrary rtc example hacked
for the above board from the the examples. If I build this example as
distributed with EWARM, it works.
The project is at:
http://www.maccelari.com/rtc.zip
I then took the C files, added the STR71x .S files for gcc and the .ld
files and built it with WinARM-20060606. The resulting bin file does
not work. As a newbie, I am completely stumped.
Does anyone have a suggestion as to where the problem may lie?
I have also tried Martin Thomas' str71_bootloader (with the button
set to Pin 1.14 instead of 1.8) and also cannot get it to work.
I have also tried several other projects and all refuse to run
on my board if compiled and built with WinARM. They all work with
EWARM!!!
Thanks
Jeremy
> The project is at:
> EWARM!!!
Since your are porting from EWARM to gnu you migth have fall into a
"trap".  In code done for IAR EWARM I often found bitfields to access
hardware-registers. For arm-gcc (at least up to Ver 4.1.2, I have not
tested 4.2.x) this does not work (well sometimes it will...) since some
of the bitfield-accesses get optimized to assembler-instructions for
8bit/byte read/write which are not allowed for hardware-register access.
So review your c-sources for lines like regfoo.bitxy = 1 and repleace
them with REGFOO |= (1UL << bitxypos) where REFOO points to the same
register (address).
About the bootloader: I have tested it successfully with an STR710
eval-board from ST. Since the STR711 might be a little different it's
possible that small modifications are needed. I do not have a board with
an STR711 here for tests.
Regards,
Martin Thomas
Martin,
Sorry - we don't use bitcodes at all!
Thanks
Jeremy
