Forum: ARM programming with GCC/GNU tools Problem with YAGARTO (_spawnv: no such file.)
Author: Dim Alex (kobe8)
Hello,
I'm trying to evaluate the YAGARTO package. The compiler is responding
normally to the command C:\>arm-elf-gcc --version, but I got an error
message when trying to compile a simple main.c file (arm-elf-gcc
main.c).
The message is: "arm-elf-gcc: _spawnv: no such file or directory"
I don't know how to solve it.
Is there anybody that could help?
Thanks in advance!
Dimitar
Author: Stefan (Guest)
Dimitar Alexandro wrote:
> Hello,
> main.c).
> Thanks in advance!
> Dimitar
Such a problem is well known with OLDER versions of WinARM in
combination with Windows98SE as host machine.
See bugreport at
http://en.mikrocontroller.net/topic/62432
And fix from Martin Thomas
http://en.mikrocontroller.net/topic/67766
Maybe you are in the very same situation with YAGARTO?
Stefan
>> Hello,
>> main.c).
>> Thanks in advance!
>> Dimitar
> See bugreport at
> Stefan
Thank You Stefan, but I still don't find the solution.
Before posting here I've searched the forum for a similar bug repots as
mine one, but I was suprised that the bug is reported only for WIN98SE.
Sorry, but I forgot to tell you that I'm using WIN XP PRO + SP2 :( I
also got the same error message on WIN XP PRO SP1.
This really freaks me, how come this happens only to me???
I haven't tried yet with the compiler in the WINARM collection, only
with the latest package from YAGARTO.
Dimitar
Author: Fordp (Guest)
Check your path.
Fordp wrote:
> Check your path.
I've done it, it sems to be OK, here it is:
<em>
C:\Program Files\Atmel\WinAVR\bin;
C:\Program Files\Atmel\WinAVR\utils\bin;
C:\PROGRA~1\Borland\CBUILD~1\Projects\Bpl;
C:\PROGRA~1\Borland\CBUILD~1\Bin;
%SystemRoot%\system32;
%SystemRoot%;
%SystemRoot%\System32\Wbem;
C:\PROGRA~1\Tcl\bin;
c:\ed\cadtools\mlxbin;
%XILINX%\bin\nt;
C:\Program Files\Altium2004 SP2\System;
C:\PROGRA~1\CA\SHARED~1\SCANEN~1;
C:\PROGRA~1\CA\ETRUST~1;
"C:\Program Files\Symantec\Norton Ghost 2003\";
C:\Program Files\openocd-2006re100\bin;
C:\Program Files\openocd-2006re100\utils\bin;
C:\Program Files\yagarto\bin
</em>
Do you see something not OK or missing?
I use a clean path variable on my system with autoexec.bat and a
selection of the one and only toolchain i want to work with (there are
10 to select from now ;-). You can also try to put the definitions
needed for arm gnu toolchain in the path on the first place.
Paths with blank might give trouble in the toolchain when not quoted.
Check the command lines and batchfiles whether commands are quoted e.g.
"c:\program files\...". Or move the toolchain to a path without blanks.
And just a hint:
 "C:\>arm-elf-gcc..." - i wouldn't really like to compile in the root
directory of the system partition ;-)
Stefan
Author: Michael Fischer (mifi)
Hello Dimitar,
I have checked it here, and installed the toolchain under
c:\Program Files. I have no problem, and I use WIN XP PRO + SP2 too.
This was my main.c:
int main (void)
  return(0);
How does your main.c looks like?
Regards,
Michael
Michael Fischer wrote:
> Hello Dimitar,
> This was my main.c:
> int main (void)
>   return(0);
> Regards,
> Michael
Hello Michael,
I'm strictly following the instructions of your HOW TO page -
http://www.yagarto.de/howto/yagarto1/index.html
Thus my main.c programme is the same as yours.
I'm going to try the WINARM compilation, as there is the same compiler
inside (GCC-4.1.1)
Thanks for the suggestion,
Dimitar
Stefan, thanks for the hints, but still nothing. I've tried with a clean
PATH variable (SET PATH C:\Program Files\openocd-2006re100\bin;
C:\Program Files\openocd-2006re100\utils\bin; C:\Program
Files\yagarto\bin) but it didn't worked.
> And just a hint:
I also don't like it, but the location is not the problem.
I thin there is nothing wrong with the PATH, since the compiler responds
correctly to the arm-elf-gcc --version, it could be invoked from
anywhere.
Dimitar
> Stefan
A working command arm-elf-gcc --version says nothing (almost).
The compiler driver gcc has to invoke other programs such as the
preprocessor and the assembler. This works through the _spawnv function.
You can check file search paths with the free FILEMON tool from
www.sysinternals.com
Try SET PATH "C:\Program Files\openocd-2006re100\bin";"C:\Program
Files\openocd-2006re100\utils\bin";"C:\Program Files\yagarto\bin"
I would also try to copy yagarto to c:\yagarto and use this path
SET PATH C:\yagarto\bin;"C:\Program
Stefan
> Stefan
Stefan, thanks once again for your comments.
I've tried your both suggestions, still don't work :_(
When I tried to use the compiler from the WINARM collection (SET
PATH=C:\Program Files\Atmel\WinARM\bin;C:\Program
Files\Atmel\WinARM\utils\bin) I didn't got the annoying message
(arm-elf-gcc: _spawnv: no such file...), but the foloowing errors:
C:\Temp>arm-elf-gcc main.c
c:/program
files/atmel/winarm/bin/../lib/gcc/arm-elf/4.1.1/../../../../arm-elf/l
ib\libc.a(exit.o): In function `exit':
exit.c:(.text+0x28): undefined reference to `_exit'
c:/program
ib\libc.a(mallocr.o): In function `_malloc_r':
mallocr.c:(.text+0x424): undefined reference to `_sbrk_r'
mallocr.c:(.text+0x4cc): undefined reference to `_sbrk_r'
c:/program
ib\libc.a(freer.o): In function `_malloc_trim_r':
mallocr.c:(.text+0x48): undefined reference to `_sbrk_r'
mallocr.c:(.text+0x64): undefined reference to `_sbrk_r'
mallocr.c:(.text+0x84): undefined reference to `_sbrk_r'
The main.c programme is as follows:
int main (void)
  return(0);
I'm going into deep sh*t. I expected a problem with the linker, not with
the compiler....:_(
I'll appreciate any tips concerning the WINARM.
Dimitar
Hello Dimitar,
your last errors are good errors :-)
The WinARM collection comes without the syscalls,
you must replace it by yourself. The examples from WinARM
has a file called syscalls.c, here you could find the
funtions like: _sbrk_t, exit and so on.
Take a look at the examples.
Best regards,
Michael
> Hello Dimitar,
> Best regards,
> Michael
Michael, thanks for the good news and for the info.
Indeed I didn't checked the examples yet.
I hope that finally I'm on the right track.
Best regards,
Dimitar
> Hello Dimitar,
> Best regards,
> Michael
Hello Michael
perhaps you can change the gcc source the same way Martin Thomas did in
order to fix the _spawnv/_spawnvp problem. I get the very same error
with Yagarto on Win98SE which i got with older versions of WinARM too.
Matin patched the source with a change from the gcc CVS source tree and
the error was gone...
Another "problem" - during installation of Yagarto on Win98SE the PATH
in autoexec.bat was not updated. Perhaps some hints in the doc what PATH
is required is useful too.
Bye
Stefan
Hello Stefan,
I do not know which patch I must use. I have NO Win98SE here, only XP.
Therefore I could not test if the patch is working.
@Martin
Which patch you have used to solve this problem?
Actually I would like to wait for the official release which
has fix the problem. The other problem will be OpenOCD.
I belive that OpenOCD is not working under Win98, or is it?
Yes this is correct, I do not set any PATH in the autoexec.bat. I use
some registry entries to set the path under XP. The GCC was created
with:
--enable-win32-registry=yagarto
Therefore you must set some keys in the registry too.
I do not know if this is working under Win98 too?
HKLM\SOFTWARE\Free Software Foundation\yagarto
Here the path for BINUTILS, G++ and GCC is set.
I will add a not on the page.
Best regards,
Michael
As far as i understand, the problem is, that the bug and the fix is well
known long time ago but it didn't make it into gcc 4.x. I do volunteer
for testing on Windows98SE.
OpenOCD... I have no problems with OpenOCD-pp R100 from Yagartos
download site and gdb/insight from GNUARM toolchain on Windows98SE.
There is a error message that giveio.sys can not be installed but this
is no problem when debugging.
The registry entries... i'll check this with REGMON, but i think my
shell programs (4DOS or bash/Cygwin) don't check these entries. I use a
similar entry like in the WinARM or GNUARM toolchains
(PATH=...\Yagarto\bin;%PATH%) now and arm-elf-gcc is starting, but i
can't check the whole toolchain because of the _spawnv/_spawnvp problem.
Stefan
Maybe you can understand Martin's changes from this reply:
Hello Stefan,
can you contact me off-list?
You will find my email address at the imprint.
Regards,
Michael
Author: Martin Thomas (Guest)
> @Martin
Check your e-mail inbox. But I don't know if the modification for
Win9x-compatiblity is related to the OP's problem since he uses XP.
Anyway, I don't think there will be any negative side-effect if you also
use the updated version of the pex-file in Yagarto. The gcc in WinARM
and WinXSCALE have not been configured with the registry-option (see
arm-elf-gcc -v).
Stefan wrote:
> Hello Michael
I was now successful with Yagarto on Windows98SE. I used the same binary
patch method for arm-elf-gcc.exe that is described for WinAVR already
(*). The very same patch was applied to collect2.exe as well.
Within Eclipse i needed to switch from internal (?) make to an external
make program. I took the make from the utils-folder of WinAVR. I think
this is a native MinGW make. One minor problem with Eclipse still exists
- there is an exception when Eclipse is closed.
(*) Beitrag "Re: avr-gcc: _spawnv: No such file or directory"
Author: Bronislav Gabrhelik (bgabrhelik)
I have just installed yagarto
yagarto-bu-2.17_gcc-4.1.1-c-c++_nl-1.14.0_gi-6.5.5.exe on vista into
C:\sw\yagarto and I am faced to the same problem. I used process monitor
from sysinternals to track down what is happening. Problem is that
gcc-elf-arm process cannot find cc1.exe. I am attaching log, where gcc
tries to find cc1.exe. It is almost successful with the first try, but
problem is that it asks for cc1 without extension .exe.  To be complete
I am trying to compile simple main.c in c:\temp. I am going to download
Windows debugging tools, so I can see stack of these system calls with
symbols. It will show which API is used for this search.
For example request below has stack which I am attaching. It calls CRT
function _stat32() which calls FindFirstFileA()...
I hope it helps finally resolve issue.
With regards
Bronislav
14759  23:02:32,8982603  arm-elf-gcc.exe  3968  QueryDirectory
C:\sw\yagarto\libexec\gcc\arm-elf\4.1.1\cc1  NO SUCH FILE  Filter: cc1
Author: Jim Kaz (ancaritha)
This is a bug in GCC 4.1.1.  It called _spawnv incorrectly, and has been
all along.  However, previous versions of windows did not valid the
parameters and it just happened to work.  Vista does valid parameters,
and so rejects the call.  This error is fixed in GCC 4.1.2.  If you do a
google search theres some more information on the matter.
