Forum: ARM programming with GCC/GNU tools linking with libc
von Denis K. (term)
Hi!
I have a problem, with using <stdio.h> functions
I've downloaded WinARM, and found that examples are not working. There
are much error in Makefile(or I'm doing something wrong)
I tried to use libc functions, including in my main.c file <stdio.h>,
linking with syscalls.c(from WinARM's example), adopted for my needs and
-lc option to the linker(link with libc.a)
but linker said me, that in can't find symbol 'printf'.
here is my Makefile looks like:
all:
  arm-elf-as --traditional-format -mthumb-interwork -k -EL -W
-mcpu=arm7tdmi -o init.o init.asm
  arm-elf-gcc -IC:\WinARM\arm-elf\include -mlittle-endian
-mthumb-interwork -mcpu=arm7tdmi -c -o test.o test.c
-mthumb-interwork -mcpu=arm7tdmi -c -o syscalls.o syscalls.c
  arm-elf-ld -o test.out --entry 0x00 -Ttext 0x00
-LC:\WinARM\arm-elf\lib -lc syscalls.o init.o test.o
  arm-elf-objcopy -O binary test.out prog.bin
I'm feeling that error is very simple, but I can't find it
Help me, please
Please paste the complete output of a make all for one of the examples
(i.e. WinARM\at91sam7s_example_gamma). Also send the output of make
--version . Do you use MS Vista?
von Denis K. (term)
C:\WinARM\examples\at91sam7s64_example_gamma>make
MAKE Version 5.2  Copyright (c) 1987, 1998 Inprise C
Error makefile 144: Command syntax error
Error makefile 147: Command syntax error
Error makefile 174: Command syntax error
Error makefile 180: Command syntax error
Error makefile 223: Command syntax error
Error makefile 225: Command syntax error
Error makefile 227: Command syntax error
Error makefile 311: Command syntax error
Error makefile 315: Command syntax error
Error makefile 316: Command syntax error
Error makefile 320: Command syntax error
Error makefile 322: Command syntax error
Error makefile 323: Command syntax error
Error makefile 358: Command syntax error
Error makefile 367: Command syntax error
Error makefile 368: Command syntax error
Error makefile 373: Too many rules for target 'progr
Error makefile 374: Command syntax error
Error makefile 379: Too many rules for target 'progr
Error makefile 380: Command syntax error
Error makefile 381: Command syntax error
Error makefile 413: Colon expected
Error makefile 435: Command syntax error
Error makefile 436: Command syntax error
Error makefile 437: Command syntax error
Error makefile 441: Command syntax error
Error makefile 442: Command syntax error
Error makefile 443: Command syntax error
Error makefile 454: Command syntax error
Error makefile 455: Command syntax error
Error makefile 456: Command syntax error
Error makefile 503: Command syntax error
*** 32 errors during make ***
> --version .
C:\WinARM\examples\at91sam7s64_example_gamma>make --version
MAKE Version 5.2  Copyright (c) 1987, 1998 Inprise Corp.
Incorrect command line argument: --version
Syntax: MAKE [options ...] target[s]
    -B                Builds all targets regardless of dependency dates
    -Dsymbol[=string] Defines symbol [equal to string]
    -Idirectory       Names an include directory
    -K                Keeps (does not erase) temporary files created by
MAKE
    -N                Increases MAKE's compatibility with NMAKE
    -Wfilename        Writes MAKE to filename updating all non-string
options
    -Usymbol          Undefine symbol
    -ffilename        Uses filename as the MAKEFILE
    -a                Performs auto-dependency checks for include files
    -c                Caches auto-dependency information
    -e                Ignores redefinition of environment variable
macros
    -i                Ignores errors returned by commands
    -l+               Enables use of long command lines
    -m                Displays the date and time stamp of each file
    -n                Prints commands but does not do them
    -p                Displays all macro definitions and implicit rules
    -q                Returns zero if target is up-to-date and nonzero
                      if it is not (for use in batch files)
    -r                Ignores rules and macros defined in BUILTINS.MAK
    -s                Silent, does not print commands before doing them
    -? or -h          Prints this message
      Options marked with '+' are on by default. To turn off a default
      option follow it by a '-', for example: -a-
no, I'm using Windows XP
von Denis K. (term)
my WinARM release is 20060606, if this helps you to help me
von Denis K. (term)
here is my makefile:
all: init.o syscalls.o test.o
  del test.out
#C:\WinARM\lib\gcc\arm-elf\4.1.1\  C:\WinARM\lib
init.o:  init.asm
test.o: test.c
syscalls.o: syscalls.c
clean:
  del *.o load.log prog.bin
load:
  binsize prog.bin
  C:\progra~1\atmelc~1\at91-i~1.10\sam-ba~1.6\sam-ba.exe \usb\ARM0
AT91SAM7S128-EK load.tcl > load.log
  @more load.log
(It's a FAQ. You did not read the readme.htm that comes with WinARM.)
The makefiles of WinARM-examples are made for a GNU make not for the
make-utility from Inprise/Borland. Rename the make.exe found the
C-Builder(?) directory to i.e. make_inprise.exe.
The output of make --version should start with GNU Make.
Martin Thomas
von Denis K. (term)
> Martin Thomas
I'm sorry, but I've read readme.htm couple of times
I've been added path to WinARM's make in the start of system path and
checked make version
Maybe this happened because I'm using Aston Shell(it replaces Windows
Explorer) and it can't correctly work with PATH environment variable
Found 3(!) Borlands makes and renamed all of them
Now my make version starts with GNU MAKE, and examples are making
correctly
But I steel can't make my own project
Can you, please, look to my makefile?
Maybe, you'll see my problem at first look
von Denis K. (term)
Hi, again!
I've looked, how object files are linked in examples
and tried to port that command line in my project:
arm-elf-gcc -mlittle-endian -mcpu=arm7tdmi -mthumb-interwork -I. init.o
syscalls.o test.o --output test.out -Wl,--entry=0x00,-Ttext=0x00 -lc
-lm -lc -lgcc
now project is make'ing without errors, but program is not working in
the device
With IDA(disassembler) I've found, that linker places couple of
functions BEFORE code in my init.o file
init.o file includes reset vectors, irq handlers and other
initialization, written in assembler
How can I tell the linker to place code of init.o at the start of .text
section?
von Denis K. (term)
This is me again
I think, that the answer is close
Now I have command, which links my object files without warnings
arm-elf-ld --entry 0x00 -Ttext 0x00
-LC:\\WinARM\\lib\\gcc\\arm-elf\\4.1.1\\ -Lc:\\winarm\\arm-elf\\lib\\ -o
test.out init.o syscalls.o test.o -lm -lc -lgcc -Tlink.ld
but the output functions are still not working
I wrote functions _write_r and _write to just blink a diode
an saw, that they are not even called, when I call printf function
maybe, I need to use some linker script, to have it working
I've been stuck with this library for a 3 days(!!!)
I'm in panic
The issue is mentioned at point 1 of the "remarks"-section of the readme
to WinARM20060606.
Hmm. I don't know this tool. But maybe this has been the reason.
> correctly
Well done.
> -lm -lc -lgcc
> the device
You can just use arm-elf-objdump to create a disassembly, no need for
extra tools.
> section?
Since you do not provide your own linker-script the default
linker-script is used. You can view it by arm-elf-ld --verbose. As you
can see the instructions placed first need to be in section .init. Did
you add the .section instruction in your startup-code? It may be easier
to use your own linker-script. See the examples that come with WinARM,
read the binutils ld manual and the articles at embedded.com mentioned
in the forum-thread "Embedded.com: Building Bare-Metal ARM Systems with
GNU".
> This is me again
So you managed to get the reset-vector at the first addresse executed by
the core after reset?
Which controller are you using? It might be easier to take one of the
WinARM examples that demonstrates "stdio" (including the makefile and
linker-scripts) and adapt it to your controller. Usualy porting is not
too difficult as long as the same core is in use (examples for ARM7TDMI
are included).
_write_r needs to be implemented since the newlib in WinARM is build for
"reentrant syscalls". Maybe your _write_r-function does not get called
because of the buffering. Try to add a fflush(stdout) after printf and
see if your debug-LED blinks.
Martin Thomas
von Denis K. (term)
> extra tools.
From now, I know, that using IDA is not needed, but this so convenient
> GNU".
I've used a linker-script from the examples(just changed memory settings
to AT91SAM7S128)
I didn't found in there some options, that can't be used by me.
I'll try to read all of that, but it is hard to do it, because English
is not my native language(sorry for my English, I think it's on a low
level, but I hope, you can understand me %).
Yes, I did it with link command line:
arm-elf-ld -EL --entry 0x00 -Ttext 0x00
test.out init.o syscalls.o test.o -lm -lc -lgcc -Tlink.d
> are included).
As I already said, my controller is AT91SAM7S128.
Maybe, porting example is easily then writing from zero
but I want to deeply understand, what exactly doing makefile, linker
script, etc. I think, this knowledge will help me in future.
That is why I write most of all code myself.
> Martin Thomas
I've tried to use fflush(), but this didn't help.
When I try to link with using a ld's script from examples, I see in IDA,
that from zero address appears .text section, then, at address 0x200000
appears .data, then .bss and then "abs"(I don't know, maybe this is not
real section, maybe IDA just shows it for understanding of other code.
However, I found in this section a lot of constants, eg: MODE_IRQ,
MODE_USR(used in asm init to manage modes), end, _bss_ and others)
In this case, on device the program don't even starts(no activity on
LEDs).
But, when I link without script, program works(LEDs are blinking, as
they have to do), printf still not working.
In this case, in IDA, I see, that .text section starts from zero
address(same as previous), but .data and others(.bss, abs) in
difference, of previous case, appears immediately after the .text (IN
FLASH)
this is only difference, I've found
maybe problem is in "abs" section?
meybe, this section really contains constants, which asm code need(and
_sbrk_r too) and script places it in RAM?
that could be a reason, why it not starting
I understand, that without script I have .data and .bss placed in FLASH
As I know, Flash controller in this chip doesn't raise exception if I'll
try to write flash with just STR command. That is why I didn't get a red
LED blinked
I've found, that you are author of WinARM.
You've got a great respect and thanks from me.
von Denis K. (term)
Maybe, you have i little of time, to look at all my project
ftp://public.ntu-kpi.kiev.ua/incoming/4Den/proj.zip (7.51 kbytes)
