Forum: ARM programming with GCC/GNU tools Question about WinARM examples: stack settings, mode etc
von Chic (Guest)
Hi all,
First of all I'm a newbie in ARM programming. I've a TinyArm evaluation
board with a LPC2194 on it and have download WinArm which I want I to
used it for the board.
As this moment I'm looking at the example: lpc2129_adc_stdio.
I have the following questions about this example:
1) In the link script file (lpc2129-rom.ld)I see:
MEMORY
  ROM (rx) : ORIGIN = 0x00000000, LENGTH = 0x0003E000
  RAM (rw) : ORIGIN = 0x40000000, LENGTH = 0x00004000
Is 3E000 correct? Shouldn't this be 40000? Because the Lpc2129 (like the
2194) has  256kb of Flash (256 * 1024 = 262144 == 0x040000).
2) The stacksize of the different mode is set in the startup file
crt0.s.
The last code of this is:
        sub   r0,r0,#SVC_STACK_SIZE
        msr   CPSR_c,#MODE_SYS|I_BIT|F_BIT // System Mode
        mov   sp,r0
Does this mean that the program run is System mode and with interrupt
disabled?
If I want to use interrupts (vectored and FIQ) must I set it to user
mode, or do  I only have to remove |I_BIT|F_BIT?
3) Where should I set the (user) stack size? In crt0.s? (How?) or in the
makefile?
4) Can someone explain me the difference(s) of the two link script
files?
Why there are two of them?
5) Where can I find tutorials about setting up the startup file,
makefile and the linker script files.
6) Where can I find tutorials about debugging (open OCD) via the Jtag
connection?
Very much thanks in advance for your answers.
Kind regard,
Chic
> MEMORY
I currently do not remember why I used a shorter length. Maybe I planed
to use the remaining flash to store configuration-values (with IAP) in
another application. Length 256K should work too.
> crt0.s.
>         mov   sp,r0
> disabled?
Yes. (Do you read comments?)
You can choose between system- and user-mode. If you use system-mode you
can swith the I and F bit in CPSR anytime in the application to disable
or enable INT/FIQ-exceptions. In user-mode this is not allowed. Just
removing the bit-masks will let "the program" (main()) start in
system-mode with INT/FIQ enabled.
If you'd like to let the program run in user-mode with INT/FIQ enabled
you can change the code like this:
replace: msr   CPSR_c,#MODE_SYS|I_BIT|F_BIT // System Mode
with:  msr   CPSR_c,#MODE_USR // User Mode INT/FIQ enabled
> makefile?
Top of stack for the application - either in USR- or SYS-Mode is the
address for _stack assigned by the linker (_stack) minus the sizes of
the stacks for the other modes. In the example total size of all stacks
is defined in the linker-script (STACK_SIZE) stack sizes for the
differnt modes are defined in crt0.S.
> files?
Search for > ROM and > RAM to see the difference. One script lets the
linker assign "fixed" values (code, consts) in the flash-memory ("ROM")
and "variable" values (data, bss) in SRAM ("RAM"). The other script puts
everything into the RAM memory adresse-range. Useful for debugging in
RAM.
Makefiles: see the GNU make manual
Linker-scripts: see the ld manual (part of the GNU binutils)
Startup-files depend on the architecture. There are documents on
www.arm.com and at least one applcation note from Atmel for AT91
ARM7TDMI but can be adpated easily for other devices based on this ARM
core like the LPC2129.
> connection?
Michael Fischer has some information on his pages www.yagarto.de.
Martin Thomas
von ChiC (Guest)
Hi Martin,
Thank you very much for taking the time to answer my questions.
Regards,
ChiC
