Forum: ARM programming with GCC/GNU tools WinArm and sprintf
von Timo (Guest)
How can i use sprintf function with WinArm gcc compiler. When i try use
the sprintf function , comes next error:
Linking: main.elf
arm-elf-gcc -mthumb -mcpu=arm7tdmi-s -mthumb-interwork -I. -gdwarf-2
-DROM_RUN  -Os -Wall -Wcast-align -Wcast-qual -Wimplicit
-Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wshadow
-Wunused -Wa,-adhlns=crt0.lst  -I../Common_WinARM/inc -MD -MP -MF
.dep/main.elf.d crt0.o  ../Common_WinARM/src/Startup.o
../Common_WinARM/src/swi_handler.o  ../Common_WinARM/src/irq.o
../Common_WinARM/src/target.o ../Common_WinARM/src/timer.o main.o
efsl_time_LPC.o extint.o adc.o spi.o  humi.o write_sd.o      --output
main.elf -nostartfiles -Wl,-Map=main.map,--cref -lc -lnewlib-lpc -lm -lc
-lgcc   -lefsl -L../../ -TLPC2138-ROM.ld
c:/winarm/bin/../lib/gcc/arm-elf/4.1.1/../../../../arm-elf/bin/ld.exe:
Warning: c:\winarm\arm-elf\bin\../lib\libnewlib-lpc.a(_close_r.o) does
not support interworking, whereas main.elf does
Warning: c:\winarm\arm-elf\bin\../lib\libnewlib-lpc.a(_fstat_r.o) does
Warning: c:\winarm\arm-elf\bin\../lib\libnewlib-lpc.a(_lseek_r.o) does
Warning: c:\winarm\arm-elf\bin\../lib\libnewlib-lpc.a(_read_r.o) does
Warning: c:\winarm\arm-elf\bin\../lib\libnewlib-lpc.a(_sbrk_r.o) does
Warning: c:\winarm\arm-elf\bin\../lib\libnewlib-lpc.a(_write_r.o) does
Warning: c:\winarm\arm-elf\bin\../lib\libnewlib-lpc.a(_ioctl_r.o) does
c:\winarm\arm-elf\bin\../lib\libnewlib-lpc.a(_sbrk_r.o)(_sbrk_r):
warning: interworking not enabled.
  first occurrence:
c:/winarm/bin/../lib/gcc/arm-elf/4.1.1/../../../../arm-elf/lib/thumb/int
erwork\libc.a(freer.o):
thumb call to arm
In function `_malloc_trim_r':
mallocr.c:(.text+0x2c): warning: internal error: dangerous error
  first occurrence:
thumb call to arm
mallocr.c:(.text+0x3c): warning: internal error: dangerous error
  first occurrence:
thumb call to arm
mallocr.c:(.text+0x48): warning: internal error: dangerous error
c:\winarm\arm-elf\bin\../lib\libnewlib-lpc.a(_fstat_r.o)(_fstat_r):
  first occurrence:
erwork\libc.a(makebuf.o):
thumb call to arm
In function `__smakebuf':
makebuf.c:(.text+0x1c): warning: internal error: dangerous error
makebuf.c:(.text+0xb2): undefined reference to `isatty'
  first occurrence:
erwork\libc.a(mallocr.o):
thumb call to arm
In function `_malloc_r':
mallocr.c:(.text+0x2e8): warning: internal error: dangerous error
  first occurrence:
thumb call to arm
mallocr.c:(.text+0x388): warning: internal error: dangerous error
c:\winarm\arm-elf\bin\../lib\libnewlib-lpc.a(_close_r.o)(_close_r):
  first occurrence:
erwork\libc.a(stdio.o):
thumb call to arm
In function `__sclose':
stdio.c:(.text+0xc): warning: internal error: dangerous error
c:\winarm\arm-elf\bin\../lib\libnewlib-lpc.a(_lseek_r.o)(_lseek_r):
  first occurrence:
thumb call to arm
In function `__sseek':
stdio.c:(.text+0x2a): warning: internal error: dangerous error
  first occurrence:
thumb call to arm
In function `__swrite':
stdio.c:(.text+0x6e): warning: internal error: dangerous error
c:\winarm\arm-elf\bin\../lib\libnewlib-lpc.a(_write_r.o)(_write_r):
  first occurrence:
thumb call to arm
stdio.c:(.text+0x86): warning: internal error: dangerous error
c:\winarm\arm-elf\bin\../lib\libnewlib-lpc.a(_read_r.o)(_read_r):
  first occurrence:
thumb call to arm
In function `__sread':
stdio.c:(.text+0xaa): warning: internal error: dangerous error
c:\winarm\arm-elf\bin\../lib\libnewlib-lpc.a(_close_r.o): In function
`_close_r':
_close_r.c:(.text+0x38): undefined reference to `device_table'
c:\winarm\arm-elf\bin\../lib\libnewlib-lpc.a(_read_r.o): In function
`_read_r':
_read_r.c:(.text+0xa0): undefined reference to `device_table'
c:\winarm\arm-elf\bin\../lib\libnewlib-lpc.a(_write_r.o): In function
`_write_r':
_write_r.c:(.text+0xe8): undefined reference to `device_table'
c:\winarm\arm-elf\bin\../lib\libnewlib-lpc.a(_ioctl_r.o): In function
`_ioctl_r':
_ioctl_r.c:(.text+0x48): undefined reference to `device_table'
make.exe: *** [main.elf] Error 1
> Process Exit Code: 2
> Time Taken: 00:06
Thanx Timo
von Martin Thomas (Guest)
Timo wrote:
> Linking: main.elf
The precompiled newlib-lpc library (libnewlib-lpc.a) in the
WinARM-package 6/06 does not support interwork. You can compile your own
with interwork-support:
- add thumb-interwork switch to the compiler-parameters in
WinARM\utils\newlib_lpc*_src\makefile
- rebuild the lib (make lib)
- copy the ".a-file" to a location where the linker searches for
libraries
Hope this helps,
Martin Thomas
von Timo (Guest)
Martin Thomas wrote:
> Timo wrote:
>> Linking: main.elf
> libraries
> Hope this helps,
> Martin Thomas
Hi Martin,
Can you clarify me how the process goes. I'am so new with the makefiles.
Timo
von Francesco C. (Company: BLT Italia SRL) (the_cuf)
Hi Martin
I have the same problem and I'm new to winarm. I translated a code
written for Keil to winarm, but using the newlib I have some problem. In
first it seems that the newlib aren't  written for my processor
(LPC2378).  Moreover I attempt to compile with the thumb-interwork
switch, but I had some problems :  Where I should activate the switch in
the makefile ?  Moreover, before compiling with the switch I attempt to
compile the library "as is", that is I entered into the directory
(C:\Programmi\WinARM\utils\newlib_lpc_rel5a_src) with a dos shell and
write ARMmake (I renomined the make.exe because of conflicts with the
Borland C++ Builder installed on my PC).  The result is:
C:\Programmi\WinARM\utils\newlib_lpc_rel5a_src>armmake
Touch  Version 4.2  Copyright (c) 1998 Borland International
arm-elf-ar cr libnewlib-lpc.a _close_r.o
arm-elf-ar cr libnewlib-lpc.a _fstat_r.o
arm-elf-ar cr libnewlib-lpc.a _ioctl_r.o
arm-elf-ar cr libnewlib-lpc.a _lseek_r.o
arm-elf-ar cr libnewlib-lpc.a _open_r.o
arm-elf-ar cr libnewlib-lpc.a _read_r.o
arm-elf-ar cr libnewlib-lpc.a _sbrk_r.o
arm-elf-ar cr libnewlib-lpc.a sys_dev.o
arm-elf-ar cr libnewlib-lpc.a sys_mam.o
arm-elf-ar cr libnewlib-lpc.a sys_pll.o
arm-elf-ar cr libnewlib-lpc.a sys_time.o
arm-elf-ar cr libnewlib-lpc.a sys_vic.o
arm-elf-ar cr libnewlib-lpc.a sys_vpb.o
arm-elf-ar cr libnewlib-lpc.a uart0_poll.o
/usr/bin/sed: -e expression #1, char 61: unterminated `s' command
arm-elf-ld -v -otest2.prg -L.  crt0.o test2.o _close_r.o _fstat_r.o
_ioctl_r.o _
lseek_r.o _open_r.o _read_r.o _sbrk_r.o sys_dev.o sys_mam.o sys_pll.o
sys_time.o
 sys_vic.o sys_vpb.o uart0_poll.o uart0_int.o uart1_poll.o uart1_int.o
_write_r.
o interrupt_sup.o uart0_ishell.o uart1_ishell.o -Tlpc210x.ld
GNU ld version 060606 20060606
arm-elf-ld: cannot find -lgcc
armmake: *** [test2.prg] Error 1
As you can see it seems that the makefile starts the Borland Touch.  I
can't find the point in the makefile in order to correct this.
Where I can find a step by step tutorial ?  For a programmer that comes
from Keil it's very difficult to start with WinARM.
Thanks in advance for help.
Francesco Cuzzocrea wrote:
> Hi Martin
> (LPC2378).
I guess you mean newlib-lpc not newlib. The newlib is a "generic" libc
and newlib-lpc is an "add-on" to fill newlib's stubs to interface with
the LPC-hardware. newlib-lpc is made be Aeolus
Yes, I guess the newlib-lpc is not written for the LPC23xx/24xx. These
parts use a different vector-controller which needes a slightly
different setup.
Borland? Does not look good. GNU shell utils should be used (MinGW,
cygwin etc).
hmm. This does not look that good. Please check source-archive of WinARM
again. There should be another makefile which I used to build
newlib-lpc.
> _ioctl_r.o _
> sys_time.o
> _write_r.
not good. Maybe because of fixed path-names in the original makefile
from Aeolus. Try to find the other makefile and use it for another test.
Yes esp. the handling how stdio is attached to the hardware is a little
different but the concept is the same. Please note that stdio-functions
from the newlib need more memory than the ones from Keil's libc. If you
just need sprintf without floating-point-support it might be a good idea
to look for an alternate implementation which does not depend on
newlib/newlib-lpc. IRC there is some code for a sprintf-replacement in
the examples of the TNKernel source-package.
