Forum: ARM programming with GCC/GNU tools lwip TCP sockets
Author: Rick (Guest)
I am using lwip for my microcontroller (AT91SAM7x256).
The webserver is running good.
Now I like a communication by TCP sockets.
When using   lwip-1.1.0/src/api/sockets.c , I have to add this to my
makefile.
Where must I add this?
I did the following:
LWIP_THUMB_SRC= \
 lwip-1.1.0/src/api/sockets.c \              (I added this)
Now I get 152 compiler warnings and the OS hangs.
How can I solve this?
Regards, Rick
> makefile.
> LWIP_THUMB_SRC= \
Not enough information.
Paste at least the beginning of the output including the 15 first
warning. Maybe you have just missed to add the additional
include-directorys to the include-search-path (extraincdirs in WinARM
sample-makefiles).
Author: Jonathan Dumaresq (dumarjo)
>> makefile.
>> LWIP_THUMB_SRC= \
> sample-makefiles).
If you have the webserver running, i don't see why you need to add
something in the make file?, since the webserver use TCP, everything
sould be there
Jonathan
Author: Andy Kunz (andykunz)
> sould be there
It's because the webserver doesn't use sockets.h - it uses the API.
I have coded several programs using both methods (in the same app -
works fine).  The sockets form is useful when starting from standard
applications, but it does not perform any of the checks (or support
timeouts) as you would probably want.  The API form means you have much
more to code, but your code can be much more robust.
As to why it isn't working, we need to see a bit more information.  I
simply added sockets.h (and other .h files) until the compiler was able
to find all the pieces it needed.
Make sure you get the path correct for the file you are including.  Make
sure it is actually there, too.
Andy
>> sould be there
> Andy
I see now.
thanks for the info Andy.
Jonathan
