Forum: ARM programming with GCC/GNU tools make.exe: *** No rule to make target `all'. Stop.
Author: Zoran Arsovski (Guest)
I'm newbie in this field. I want to compile uSmartX with WinARM but I
got this following message:
> "make.exe" all
> Process Exit Code: 2
> Time Taken: 00:01
This is my makefile for any case:
# Makefile for ARM target
# Define directories.
  uSMARTX_INC_DIR = ../../../inc/
  uSMARTX_SRC_DIR = ../../../src/
  uSMARTX_HAL_DIR = ../../hal/
  uSMARTX_HAL_INC_DIR = ../inc/
# Define programs.
  AR = arm-elf-ar
    COMPILE = arm-elf-gcc
    ASSEMBLE = arm-elf-gcc -x assembler-with-cpp
    REMOVE = rm -f
    COPY = cp
    MOVE = mv
# MCU name
  MCU = arm7tdmi
# Output format. Can be [srec|ihex].
    FORMAT = ihex
# Target file name (without extension).
  TARGET = libusmartx
# List C source files here.
  SRC =  $(uSMARTX_SRC_DIR)usmartx.c \
      $(uSMARTX_SRC_DIR)queue.c \
      $(uSMARTX_SRC_DIR)mailbox.c \
      $(uSMARTX_SRC_DIR)semaphore.c \
      $(uSMARTX_SRC_DIR)mballoc.c \
      $(uSMARTX_SRC_DIR)cycbuff.c \
# List Assembler source files here.
  ASRC = $(uSMARTX_HAL_DIR)hal_gnu.s
# Compiler flags.
  CPFLAGS = -c -g -O2 -Wall
# Assembler flags.
    ASFLAGS = -Wa,-ahlms=$(<:.s=.lst),--gstabs
# Linker flags (passed via GCC).
  LDFLAGS =
# Additional library flags (-lm = math library).
  LIBFLAGS =
# Define all project specific object files.
  OBJ  = $(SRC:.c=.o) $(ASRC:.s=.o)
# Define all listing files.
  LST = $(ASRC:.s=.lst) $(SRC:.c=.lst)
# Compiler flags to generate dependency files.
  GENDEPFLAGS = -Wp,-M,-MP,-MT,$(*F).o,-MF,.dep/$(@F).d
# Add target processor to flags.
     CPFLAGS += -mcpu=$(MCU) $(GENDEPFLAGS)
  ASFLAGS += -mcpu=$(MCU)
  LDFLAGS += -mcpu=$(MCU)
# Default target.
.PHONY : Lib
Lib: Clean $(TARGET).a clear_output
# Link: create ELF output file from object files.
.SECONDARY : $(TRG).elf
.PRECIOUS : $(OBJ)
%.a: $(OBJ)
  $(AR) rs $(TARGET).a $(OBJ)
# Compile: create object files from C source files.
%.o : %.c
  $(COMPILE) -c $(CPFLAGS) -I$(uSMARTX_INC_DIR) -I$(uSMARTX_HAL_INC_DIR)
$< -o $@
# Assemble: create object files from assembler files.
%.o : %.s
  $(ASSEMBLE) -c $(ASFLAGS) $< -o $@
# Target: clean project.
.SILENT : Clean
.PHONY : Clean
Clean :
  $(REMOVE) $(TARGET).hex
  $(REMOVE) $(TARGET).obj
  $(REMOVE) $(TARGET).elf
  $(REMOVE) $(TARGET).bin
  $(REMOVE) $(TARGET).map
  $(REMOVE) $(TARGET).sym
  $(REMOVE) $(TARGET).lnk
  $(REMOVE) $(TARGET).lss
  $(REMOVE) $(OBJ)
  $(REMOVE) $(LST)
  $(REMOVE) $(SRC:.c=.s)
# Target clear output files
.SILENT : clear_output
.PHONY: clear_output
clear_output :
  $(RM)  $(uSMARTX_SRC_DIR)*.o
  $(RM)  *.o
# Include the dependency files.
-include $(shell mkdir .dep 2>/dev/null) $(wildcard .dep/*)
# List assembly only source file dependencies here:
If someone can help me with this problem I will be very greatful.
Thanks in advance
Author: Stefan (Guest)
I also see no line for target 'all'. Seems your "all" target is renamed
'Lib'. Do you try to make a library? Call make with 'make Lib'
