Forum: ARM programming with GCC/GNU tools Big problem with EFSL by M. Thomas
von Artur B. (ar2ras)
Hi, I have downloaded the library with EFSL by M.Thomas, but i can't
compile any examples in WinARM, because compiler shows this:
Assembling (ARM-only): crt0.S
arm-elf-gcc -c -mcpu=arm7tdmi-s -mthumb-interwork -I. -x
assembler-with-cpp -DROM_RUN -Wa,-adhlns=crt0.lst,-gdwarf-2 crt0.S -o
crt0.o
Compiling C: main.c
arm-elf-gcc -c -mthumb -mcpu=arm7tdmi-s -mthumb-interwork -I. -gdwarf-2
-DROM_RUN  -Os -Wall -Wcast-align -Wcast-qual -Wimplicit
-Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wshadow
-Wunused -Wa,-adhlns=main.lst  -I../../inc -I../../conf -MD -MP -MF
.dep/main.o.d -Wstrict-prototypes -Wmissing-declarations
-Wmissing-prototypes -Wnested-externs  -std=gnu99 main.c -o main.o
In file included from ../../inc/efs.h:37,
                 from main.c:17:
../../inc/types.h:41:20: error: config.h: No such file or directory
In file included from ../../inc/efs.h:39,
                 from main.c:17:
../../inc/interface.h:50:3: error: #error "NO INTERFACE DEFINED - see
interface.h"
In file included from ../../inc/disc.h:41,
                 from ../../inc/efs.h:40,
                 from main.c:17:
../../inc/ioman.h:61: error: expected specifier-qualifier-list before
'hwInterface'
../../inc/ioman.h:100: error: expected declaration specifiers or '...'
before 'hwInterface'
In file included from main.c:17:
../../inc/efs.h:51: error: expected specifier-qualifier-list before
'hwInterface'
In file included from main.c:18:
../../inc/ls.h:44: error: 'LIST_MAXLENFILENAME' undeclared here (not in
a function)
main.c: In function 'main':
main.c:132: error: 'EmbeddedFileSystem' has no member named 'myFs'
main.c:140: error: 'EmbeddedFileSystem' has no member named 'myFs'
main.c:150: error: 'EmbeddedFileSystem' has no member named 'myFs'
main.c:162: error: 'EmbeddedFileSystem' has no member named 'myFs'
main.c:172: error: 'EmbeddedFileSystem' has no member named 'myFs'
main.c:182: error: 'EmbeddedFileSystem' has no member named 'myPart'
make: *** [main.o] Error 1
but there are fields myFs and myPart in structure EmbendedFileSystem
please anybody help me :)
von Jonathan D. (dumarjo)
> Compiling C: main.c
>                  from main.c:17:
>                  from main.c:17:
you should correct the config.h file before trying to get the rest
working.
the compiler dosen't seem to be able to find config.h. I don't know why
but you should check this at first.
regards
Jonathan
von Martin Thomas (Guest)
Jonathan Dumaresq wrote:
>> Compiling C: main.c
>>                  from main.c:17:
>>                  from main.c:17:
> working.
There is no config.h in the package but several "templates" are provided
for different targets in the config-directory. The easiest method is to
copy one of the templates to a file named config.h in the same directory
and modify the settings.
IRC this is explained in the documenation (original pdf and my
additional readme-file).
BTW: the efsl has not been created by me. I have just implemented some
of the SD/SPI backend-code for LPC2000 and AT91SAM7 (and others, but I'm
still testing) and contributed some smaller extensions and fixes. Since
the efsl-maintainers seem to be very busy and my changes have not been
merged into the official release I temporarly provide a source-package
with some updates and extended examples.
Martin Thomas
OK, Thank You very much!! It's working now :):)
