Forum: ARM programming with GCC/GNU tools Problems with Yagarto/Eclipse/C++ Programming
Author: Flying Arm (flying)
Hi
I am working with yagarto eclipse ide, i am trying to write simple
programs for AT91SAMX256 Olimex board.
I tried to flash the sample program written in c it works fine.
Now i like to do my programming in c++.
What things i need to chnage for example makefile , compiler.
I am using the compiler arm-elf-g++ and the main file to .cpp extension.
I will be really thankful if anyone can help me out in this issue.
Have a nice day ahead.
Regards
Flying
Author: Jonathan Dumaresq (dumarjo)
Rajitha Dandu wrote:
> Hi
> Regards
> Flying
look on winarm example web page. I'm sure you will find a sample for
this with the correct ld file and startup file.
I know you have to put some thing there but since i have never
programmed in c++ on micro i can't help you much with this.
good luck
Jonathan
>> Hi
>> Regards
>> Flying
> good luck
> Jonathan
Thank you for your response.
I tried on WinArm Projects page .I got a linker script for other target
board , but i dont know how to change the memory locations according to
my Target board .
I have a Olimex borad with AT91SAM256.
It gives error 'no memory section defined for loadable section'.
Please help me to fix this error if anyone of you have any idea.
I will be thankful to you if you can provide me any information
regarding the Linker Scripts, makefile and the settings which i need to
do for c++ programming with Yagarto.
Regards
Rajitha
