Forum: ARM programming with GCC/GNU tools pn won't compile but cygwin will
Author: eric (Guest)
I am running WinXP and have installed WinARM using the guide at
http://winarm.scienceprog.com/winarm-tools/quick-s...
But I still can't get the sample programs to compile using pn. I added
";c:\WinARM\bin;c:\WinARM\utils\bin;" (without quotes) to the PATH
environment variable and it still doesn't compile (I tried re-booting to
ensure PATH was set). The error I get from pn is:
> "make.exe" all
-------- begin --------
process_begin: CreateProcess((null), arm-elf-gcc --version, ...) failed.
make (e=2): The system cannot find the file specified.
make.exe: *** [gccversion] Error 2
> Process Exit Code: 2
> Time Taken: 00:01
I tried compiling the program from the Cygwin command line and it works
fine (output on the bottom). I tried from Dos and I get the same output
as pn above. Any ideas? It seems to be a path problem but
";c:\WinARM\bin;c:\WinARM\utils\bin;" is in there.
Thanks,
--eric
here's the output from Cygwin:
$ make
arm-elf-gcc.exe (GCC) 4.1.1 (WinARM)
Copyright (C) 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is
NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
PURPOSE.
Assembling (ARM-only): build/crt0.S
arm-elf-gcc -c -mcpu=arm7tdmi  -I. -x assembler-with-cpp -DROM_RUN
-Wa,-adhlns=b
uild/crt0.lst,-gdwarf-2 build/crt0.S -o build/crt0.o
Compiling C: ledswitch.c
arm-elf-gcc -c  -mcpu=arm7tdmi  -I. -gdwarf-2 -DROM_RUN  -Os -Wall
-Wcast-align
-Wcast-qual -Wimplicit  -Wpointer-arith -Wswitch -Wredundant-decls
-Wreturn-type
 -Wshadow -Wunused -Wa,-adhlns=ledswitch.lst   -MD -MP -MF
.dep/ledswitch.o.d -W
strict-prototypes -Wmissing-declarations -Wmissing-prototypes
-Wnested-externs
-std=gnu99 ledswitch.c -o ledswitch.o
Linking: ledswitch.elf
arm-elf-gcc  -mcpu=arm7tdmi  -I. -gdwarf-2 -DROM_RUN  -Os -Wall
-Wcast-align -Wc
-Wreturn-type -W
shadow -Wunused -Wa,-adhlns=build/crt0.lst   -MD -MP -MF
.dep/ledswitch.elf.d bu
ild/crt0.o    ledswitch.o     --output ledswitch.elf -nostartfiles
-Wl,-Map=leds
witch.map,--cref -lc  -lm -lc -lgcc -Tbuild/LPC2106-ROM.ld
Creating load file for Flash: ledswitch.hex
arm-elf-objcopy -O ihex ledswitch.elf ledswitch.hex
Creating Extended Listing: ledswitch.lss
arm-elf-objdump -h -S -C ledswitch.elf > ledswitch.lss
Creating Symbol Table: ledswitch.sym
arm-elf-nm -n ledswitch.elf > ledswitch.sym
Size after:
ledswitch.elf  :
section           size         addr
.text              476            0
.stack            1024   1073741824
.comment            27            0
.debug_aranges      64            0
.debug_pubnames     27            0
.debug_info        249            0
.debug_abbrev      145            0
.debug_line        210            0
.debug_frame        64            0
.debug_str          92            0
.debug_loc          62            0
.debug_ranges       24            0
Total             2464
Errors: none
-------- end --------
Author: Michael Fischer (mifi)
Hello Eric,
Can you start in the dos box the following command:
The make could not find the arm-elf-gcc.
Regards,
Michael
Michael Fischer wrote:
> Hello Eric,
> Regards,
> Michael
Sorry, I forgot to include the fact that the path seems setup correctly
when using Dos:
C:\>arm-elf-gcc --version
arm-elf-gcc (GCC) 4.1.1 (WinARM)
NO
PURPOSE.
Which is the same from Cygwin:
$ arm-elf-gcc --version
NO
PURPOSE.
Is there something wrong with my PN setup?
Thanks,
--eric
Author: Martin Thomas (Guest)
Can you please try to do a make all from the "Windows-Shell" (not the
cygwin-shell/bash) just to check it's a setup-problem with the system or
PN.
c:\>cd \path\to\project
c:\path\to\project> make all
Are there any entries for cygwin or mingw in the search-Path?
Martin Thomas
> PN.
> Martin Thomas
C:\WinARM\examples\lpc2106_blink_switch>make all
make: *** [gccversion] Error 2
The call from Dos fails the same way that PN does. Just checked the Path
(both system and user) and neither of them have cygwin or mingw in them.
--eric
>> PN.
>> Martin Thomas
> --eric
I can not reproduce this problem here.
Please try the alternate utility collection from
http://www.siwawi.arubi.uni-kl.de/avr_projects/arm...
WinARM_utils_testing_20060719.zip
This has been driving me nuts but I found the problem. The problem is
close to what Martin had suggested at one point (cygwin being in my
path). Turns out that my Libero program (fpga design software) had
make.exe, sh.exe and a bunch of other similar utils; Libero put those
utils in my path.
I found this because calling "sh.exe" from the winarm's directory (in
dos) had a different prompt if I called sh.exe from any other directory.
Thanks for your help Martin.
