Forum: ARM programming with GCC/GNU tools MTs USB HID example- DBGU problem
von Ecc E. (exelty)
Hi guys,
I am having some troubles with Martin's USB HID core gnu port.  Can
anyone help? I got over the 'sh' thing, and have put in relevent SAM7A3
mods for the makefile and openocd, but after burning the code in I get
only tab characters coming out on the DBGU, has anyone else experienced
this problem?  Also the computer doesn't recognise a HID, but thats ok,
if i can get the DBGU working I should be able to debug the rest.
I have proven out the board I am using; a AT91SAM7A3 board. I have
successfully ported two of Martin Thomas's AT91SAM7S examples so far,
the openocd gamma project, and the USB-UART which I modded to be a nice
USB terminal.. (I have uploaded the UART to mt, but the usb-uart still
needs some cleaning up). I am actually attempting to make a
USB-joystick..
Anyway, help appreciated,
B
von Guest (Guest)
Ben Exelty wrote:
> Hi guys,
> USB-joystick..
> B
I have the same situation as you have with the dbgu things. I use a
sam7sek board and cannot get the first TRACE working. I also attemps to
simulate a joystick on usb.
i put this info on the makefile:
TARGET=AT91SAM7S256
BOARD=AT91SAM7SEK
CLASS=ENUM
MODE=NO
REMAP=NO
DEBUG=NO
LEDS=YES
TRACES=YES
POWER=AUTO
regards
Jonathan
von Jonathan D. (dumarjo)
Guest wrote:
> Ben Exelty wrote:
>> Hi guys,
// \brief   Puts the device back into a normal operation mode
void DEV_Resume(void)
#if defined(AT91SAM7SEK) || defined(AT91SAM7SEEK) \
    || defined(AT91SAM7XEK) || defined(AT91SAM7A3EK)
    // Enable Main Oscillator
    // Main Oscillator startup time is board specific:
    // Main Oscillator Startup Time (18432KHz) corresponds to 1.5ms
    // (0x08 for AT91C_CKGR_OSCOUNT field)
    #if defined(AT91SAM7SEK) || defined(AT91SAM7SEEK) ||
    AT91C_BASE_PMC->PMC_MOR = (AT91C_CKGR_OSCOUNT & (0x8 << 8))
                              | AT91C_CKGR_MOSCEN;
    #elif defined(AT91SAM7A3EK)
    AT91C_BASE_PMC->PMC_MOR = (AT91C_CKGR_OSCOUNT & (0x40 << 8))
                              | AT91C_CKGR_MOSCEN;
    #endif
    // Wait until the oscillator is stabilized
//    while (!ISSET(AT91C_BASE_PMC->PMC_SR, AT91C_PMC_MOSCS));
    // Set PLL to 96MHz (96,109MHz) and UDP Clock to 48MHz
    // PLL Startup time depends on PLL RC filter
    // UDP Clock (48,058MHz) is compliant with the Universal Serial Bus
    // Specification (+/- 0.25% for full speed)
    AT91C_BASE_PMC->PMC_PLLR = AT91C_CKGR_USBDIV_1
                               | AT91C_CKGR_OUT_0
                               | (AT91C_CKGR_PLLCOUNT & (0x28 << 8))
                               | (AT91C_CKGR_MUL & (0x48 << 16))
                               | (AT91C_CKGR_DIV & 0xE);
/*       AT91C_BASE_PMC->PMC_PLLR = ((AT91C_CKGR_DIV & 14 ) |
                         (AT91C_CKGR_PLLCOUNT & (28<<8)) |
                         (AT91C_CKGR_MUL & (72<<16)));*/
    // Wait until the PLL is stabilized
    while(!ISSET(AT91C_BASE_PMC->PMC_SR, AT91C_PMC_LOCK));
    //while(!(AT91C_BASE_PMC->PMC_SR & AT91C_PMC_LOCK));
    //while(!(AT91C_BASE_PMC->PMC_SR & AT91C_PMC_MCKRDY));
    // Selection of Master Clock MCK (equal to Processor Clock PCK)
equal to
    // PLL/2 = 48MHz
    // The PMC_MCKR register must not be programmed in a single write
operation
    // (see. Product Errata Sheet)
    AT91C_BASE_PMC->PMC_MCKR = AT91C_PMC_PRES_CLK_2;
    while (!ISSET(AT91C_BASE_PMC->PMC_SR, AT91C_PMC_MCKRDY));
    //SET(AT91C_BASE_PMC->PMC_MCKR, AT91C_PMC_CSS_PLL_CLK);
    AT91C_BASE_PMC->PMC_MCKR |= AT91C_PMC_CSS_PLL_CLK  ;
    //while (!ISSET(AT91C_BASE_PMC->PMC_SR, AT91C_PMC_MCKRDY));
   //* Set Flash Waite sate
#elif defined(AT91SAM9261EK)
    AT91C_BASE_PMC->PMC_IDR = 0xFFFFFFFF;
    // Setup the PLL A
    AT91C_BASE_CKGR->CKGR_PLLAR = 0x2060BF09; // crystal= 18.432MHz
    while (!(*AT91C_PMC_SR & AT91C_PMC_LOCKA));
    // Switch Master Clock from PLLB to PLLA/2
    AT91C_BASE_PMC->PMC_MCKR = AT91C_PMC_CSS_PLLA_CLK |
AT91C_PMC_PRES_CLK
                             | AT91C_PMC_MDIV_2;
    while (!(*AT91C_PMC_SR & AT91C_PMC_MCKRDY));
#elif defined(AT91RM9200)
    // Checking the Main Oscillator Frequency (Optional)
    volatile char    tmp    = 0;
    AT91F_PIOD_CfgPMC();  // VBUS
    // Determine the main clock frequency
    while(!(AT91C_BASE_CKGR->CKGR_MCFR & AT91C_CKGR_MAINRDY) && (tmp++ <
100));
#endif
but you have to put 1 more instruction before
    AT91C_BASE_MC->MC_FMR = AT91C_MC_FWS_1FWS ; <----- this line
                              | AT91C_CKGR_MOSCEN;
now the dbgu is working at least on the SAM7S-EK board
i will continue to test it today.
Jonathan
von Ecc E. (exelty)
Dude, you tha man! thanks heaps for the tip!
I had a bit more play last night and I figured it must be in the setup
because i while(1);'d the program after the first trace_init, and I
still couldn't get anything more than tabs coming out.  I probably
should have said in my first post I am actually using a custom board,
which I have defined as AT91SAM7A3_CUSTOM, which, unfortunately means
the whole clock init there has been skipped! so this must be the
problem, d'oh.  The way the DEV_init is put in the startup.S made it
tricky too.
Well I'll add my custom board to the init and see what happens, will
report back in a sec.
>                               | AT91C_CKGR_MOSCEN;
> Jonathan
von Ecc E. (exelty)
It works now!!! Thanks again.
Hmm, now for the joystick part...
von Ecc E. (exelty)
BTW i did have to add that line to get it to work Jon, and the computer
recognises a HID when i replug the USB.yay!
btw, my mt_defs is now, only:
TARGET=AT91SAM7A3
BOARD=AT91SAM7A3_CUSTOM
CLASS=HID
MODE=KEYBOARD
DEBUG=YES
POWER=BUS
Regards.B
> TARGET=AT91SAM7A3
> CLASS=HID
> MODE=KEYBOARD
> DEBUG=YES
> POWER=BUS
> Regards.B
it's a good new than !
is it possible for you marten to update your sample file with this
little modification ?
Jonathan
von Ecc E. (exelty)
Jonathan,
I am finding that it doesn't report a keyboard on the usb popup on the
PC, instead it just reports a USB HID & HID Keyboard in Device Manager
(XP system), did you find this as well? should it actually be reporting
'atmel at91 HID keyboard' as in the pProduct descriptor?
(From the debug data I can see it sends the pProduct (which is in
pStrings[2]), ie, "Hlr Ept0 Stp NewReq Std gDesc Str2 Write0(48) ")
Heres the whole log from enumeration:
Main HID keyboard
Init()
Attach(1) Connecting ... OK
Hlr Susp
Hlr Res
Hlr Susp
Hlr Res
Hlr EoBRes CfgEpt0
Hlr Res
Hlr EoBRes CfgEpt0
Hlr Ept0 Stp NewReq Std gDesc Dev Write0(18)
Hlr Ept0 Wr 8
Hlr EoBRes CfgEpt0
Hlr Ept0 Stp NewReq Std sAddr Write0(0)
Hlr Ept0 Wr 0 EoT SetAddr(1)
Hlr Ept0 Wr 8
Hlr Ept0 Wr 8
Hlr Ept0 Wr 2 EoT
Hlr Ept0 Rd Ack
Hlr Ept0 Stp NewReq Std gDesc Cfg Write0(9)
Hlr Ept0 Wr 8
Hlr Ept0 Wr 1 EoT
Hlr Ept0 Rd Ack
Hlr Ept0 Stp NewReq Std gDesc Str0 Write0(4)
Hlr Ept0 Wr 4 EoT
Hlr Ept0 Stp NewReq Std gDesc Str3 Write0(26)
Hlr Ept0 Wr 8
Hlr Ept0 Wr 8
Hlr Ept0 Wr 8
Hlr Ept0 Wr 2 EoT
Hlr Ept0 Rd Ack
Hlr Ept0 Stp NewReq Std gDesc Cfg Write0(41)
Hlr Ept0 Wr 8
Hlr Ept0 Wr 8
Hlr Ept0 Wr 8
Hlr Ept0 Wr 8
Hlr Ept0 Wr 8
Hlr Ept0 Wr 1 EoT
Hlr Ept0 Rd Ack
Hlr Ept0 Stp NewReq Std gDesc W: STD_RequestHandler: Unknown
GetDescriptor = 0x06
Stall0
Hlr Ept0 Sta
Hlr Ept0 Wr 4 EoT
Hlr Ept0 Wr 8
Hlr Ept0 Wr 8
Hlr Ept0 Wr 8
Hlr Ept0 Wr 8
Hlr Ept0 Wr 8
Hlr Ept0 Wr 8
Hlr Ept0 Wr 0 EoT
Hlr Ept0 Rd Ack
Hlr Ept0 Wr 4 EoT
Hlr Ept0 Wr 8
Hlr Ept0 Wr 8
Hlr Ept0 Wr 8
Hlr Ept0 Wr 8
Hlr Ept0 Wr 8
Hlr Ept0 Wr 8
Hlr Ept0 Wr 0 EoT
Hlr Ept0 Rd Ack
Hlr Ept0 Wr 8
Hlr Ept0 Wr 8
Hlr Ept0 Wr 2 EoT
Hlr Ept0 Rd Ack
Hlr Ept0 Wr 8
Hlr Ept0 Wr 1 EoT
Hlr Ept0 Rd Ack
Hlr Ept0 Wr 8
Hlr Ept0 Wr 8
Hlr Ept0 Wr 8
Hlr Ept0 Wr 8
Hlr Ept0 Wr 8
Hlr Ept0 Wr 1 EoT
Hlr Ept0 Rd Ack
Hlr Ept0 Stp NewReq Std sCfg Write0(0)
Hlr Ept0 Wr 0 EoT SetCfg() CfgEpt1 CfgEpt2
Read2(1) Hlr Ept0 Stp NewReq sIdle(0) Write0(0)
Hlr Ept0 Wr 0 EoT
Hlr Ept0 Stp NewReq Report Write0(57)
Hlr Ept0 Wr 8
Hlr Ept0 Wr 8
Hlr Ept0 Wr 8
Hlr Ept0 Wr 8
Hlr Ept0 Wr 8
Hlr Ept0 Wr 8
Hlr Ept0 Wr 8
Hlr Ept0 Wr 1 EoT
Hlr Ept0 Rd Ack
Hlr Ept0 Stp NewReq sReport Read0(1)
Hlr Ept0 Rd 1 EoT Write0(0)
Hlr Ept0 Wr 0 EoT
Ben Exelty wrote:
> Jonathan,
I think i have sseen something in a forum that we have to change
something (productid or vendor id) to make it work correctly.
but i haven't test it really much since i'm writing the joystick device.
regards
Jonathan
von Ecc E. (exelty)
> Ben Exelty wrote:
>> Jonathan,
> regards
> Jonathan
can you point me where maybe the forum was? I tried some different
things including changing the device descriptors, but didn't change the
name.
I think actually that if the device uses the HID standard then it
reports itself as a HID device and therefore the computer doesnt need a
idproduct becuase its already decided on a driver.  You can probably
still get access to the idproduct from within applications, the
application would just have to ask for it, the device manager just
doesnt show it. does that sound right?
Anyway, I might do the same and just go on with the joystick :P
> name.
I cannot remember where i see it, sorry.
i'm a very newbie with all the usb thing, so i cannot help you much with
this.
good :)
Jonathan
von Ecc E. (exelty)
BTW, while I remember, I found a bug in this makefile;
in the part:
>#       Check power
>ifndef POWER
>POWER = AUTO
>else
>ifneq ($POWER,BUS)
>POWER = AUTO
>endif
>endif
the:
ifneq ($POWER,BUS)
line should be:
ifneq ($(POWER),BUS)
otherwise the bus powered doesn't work as assumed!
Regards,
Exelty
von Martin Thomas (Guest)
I have update the gcc-port of the USB core and HID code from Atmel. This
version includes an updated version of make.exe (3.81) so the makefiles
of the previous port could be used without massive changes. I have also
included the modifications proposed by Jonathan Dumarjo (DEV_resume) and
ECC Exelty ($(POWER)).
http://www.siwawi.arubi.uni-kl.de/avr_projects/arm_projects/index_at91.html#at91_usb1
Quick start: type mtmake all form the command line instead of make all.
It seems that the make.exe V3.80 not only ignores the shell-variable and
always uses sh.exe when is is found in the path but also does not pass
command-line parameters to a "recursivly called" make. So sorry, the
makefiles in this release of the gcc-port are still "Win32-only" since
it uses the Windows "shell" (cmd). It will be some work to create
makefiles compatible with the old make 3.80 as in WinARM 6/06 and an
unix-type shell while keeping the "subproject"-structure as in the
original Atmel code.
Martin Thomas
> Martin Thomas
thanks Martin for your good work.
Jonathan
