Forum: ARM programming with GCC/GNU tools Error in linking
von Sla (Guest)
My project - work witch jpg files - compress/decompress
Function give error > from free jpglib >
jpeg_create_compress(&zip_cinfo);
Make all >
Linking: main.elf
c:/winarm/bin/../lib/gcc/arm-elf/4.1.1/../../../../arm-elf/lib/thumb/int
erwork\libc.a(tmpnam.o):
In function `worker':
tmpnam.c:(.text+0x32): undefined reference to `_open_r'
In function `_tempnam_r':
tmpnam.c:(.text+0xa4): undefined reference to `_getpid_r'
In function `_tmpnam_r':
tmpnam.c:(.text+0x10c): undefined reference to `_getpid_r'
erwork\libc.a(fopen.o):
In function `_fopen_r':
fopen.c:(.text+0x2c): undefined reference to `_open_r'
erwork\libc.a(remove.o):
In function `_remove_r':
remove.c:(.text+0x2): undefined reference to `_unlink_r'
make: *** [main.elf] Error 1
If compili this project in IAR, no Error.
What lib use for correct this error ?
Who type in makefile ?
von Martin Thomas (Guest)
> Make all >
> Linking: main.elf
It seems that the library uses some kind of file-access and you need to
interface your storage-driver (maybe some kind of FAT-library) to the
newlib's stdio-functions. Please read the chapter about system-calls in
the newlib-documentation. libnosys and libfat from the devkitpro-Project
should give an idea how the newlib to driver-interfaceing can be done.
It might be easier to replace the stdio-functions which own functions
(i.e. with functions provided by the embedded file system library efsl).
Martin Thomas
von Sla (Guest)
Ok.
Im' see devkitpro and this code in stdio.h for psp:
#include_next <stdio.h>
#if __SSP_FORTIFY_LEVEL > 0
#include <stdarg.h>
#undef sprintf
#undef vsprintf
#undef snprintf
#undef vsnprintf
#undef gets
#undef fgets
#define snprintf(str, len, ...) \
  __builtin___snprintf_chk (str, len, 0, __ssp_bos (str), _VA_ARGS_)
#define vsnprintf(str, len, fmt, ap) \
  __builtin___vsnprintf_chk (str, len, 0, __ssp_bos (str), fmt, ap)
e.t.c. >
#undef standart stdio function ADN #define correct function for ARM
Sla.
