Forum: ARM programming with GCC/GNU tools Error while compiling for arm, thumb interwork
von Rushikesh S. (rushikeshs)
Hello,
I am using WinARM.
I am using -mthumb-interwork option for some .c files which I need to
execure in ARM.
And I am using -mthumb for a .c file which I need to execute in thumb
mode.
My files are getting compiled correctly, but I am getting following
error while linking using arm-elf-ld
arm-elf-ld: internal error c:/winarms/binutils-060606/ld/ldlang.c 4260
What could be work around for this?
Thanks,
Rushikesh
von Martin Thomas (Guest)
Rushikesh Shingnapurkar wrote:
> Hello,
> I am using WinARM.
> execure in ARM.
> mode.
Can you tryp to build the examples that come with the WinARM package. A
lot of the examples use interwork so you can test if your basic setup
works. If yes, compare your source-files, makefile and linker-script
with the examples to find the difference. Did you use the
-mthumb-interwork option? Are the glue-sections included in the
linker-script?
Martin Thomas
I will first check the examples.
For your questions,
Yes, I did use -mthumb-interwork
and  I had glue-sections in my linker script.
Thanks,
-Rushikesh Shingnapurkar
