Forum: ARM programming with GCC/GNU tools arm-elf-ld problem
von Alexiey Rybinsky (Guest)
Hello,
I am using the latest WinARM package to compile the bootloader from this
site:
http://cq.cx/at91sam7sXXX.pl
However what I get from the linker is the following:
+ arm-elf-ld -g -Tldscript-ram-jtag --oformat elf32-littlearm -o
obj/bootrom-for
jtag.elf obj/bootrom.o obj/ram-reset.o obj/usb.o
c:\programy\WinARM\bin\arm-elf-ld.exe: internal error
c:/winarms/binutils-060606
/ld/ldlang.c 4260
make: *** [obj/bootrom-forjtag.s19] Error 1
What is the reason for this error? It seems like WinARM fault. Cany
anyone else please check and confirm it?
Regards,
Alexiey
von Stefan (Guest)
The author of this bootloader confirmed it already (indirectly)
"Also, I recommend WinterMute's build of arm-gcc. I have not been able
to get some others to work."
