Forum: ARM programming with GCC/GNU tools Amtel at91sam7s256 example needed!
Author: Kam (Guest)
Hi all,
I'm having a real pain in the ass trying to just READ a button input
from the Olimex at91sam7s256 proto board!
Here is the simple code!
volatile AT91PS_PIO pPIO = AT91C_BASE_PIOA;     // pointer to PIO data
structure
#define output_low(mask)    (pPIO->PIO_CODR=mask)
#define output_high(mask)   (pPIO->PIO_SODR=mask)
#define input(mask)         (pPIO->PIO_PDSR & mask)
//#define input(mask)         (pPIO->PIO_ODSR & mask)
#define HIGH    1
#define LOW     0
int main()
    int x;
    LowLevelInit();
    // Set up the LEDs
    pPIO->PIO_PER=LED_MASK|SW_MASK;     // bits 17,18 | 19,20
    pPIO->PIO_OER=LED_MASK;             // bits 17, 18
    pPIO->PIO_SODR=LED_MASK;            // bits 17, 18
    pPIO->PIO_ODR=SW_MASK;
    pPIO->PIO_PER=SW_MASK;
    // turn off LEDs
    output_low(LED1);
    output_low(LED2);
    while(1)
        if(input(SW1)!=LOW)
            output_high(LED1);
            output_low(LED2);
        else
            output_low(LED1);
            output_high(LED2);
    while(1);
    return 0;
Any thoughts?!
~Kam (^8*
Author: Kam (Guest)
Got it!
I was missing the following line in the init...
    pPMC=AT91C_BASE_PMC;
    //enable the clock of the PIO
    pPMC->PMC_PCER = 1 << AT91C_ID_PIOA;
~Kam (^8*
