Forum: ARM programming with GCC/GNU tools assembler error
von Kumar P. (praveen_g_v)
hi,
when i am making the example code's given
i am getting the following error
can any one help me
/usr/local/lib/gcc/arm-elf/3.4.0-macraigor1/../../../arm-elf/bin/as:unre
cognized
option '-gdwarf-2'
make:*** [Cstartup.o] Error 1
thanks.
von Patrick D. (patrick-deflandre)
Remove this '-gdwarf-2' option in your makefile.
> can any one help me
cognized
> option '-gdwarf-2'
von Clifford S. (clifford)
cognized
> option '-gdwarf-2'
To include DWARF 2 debugging information in assembler the assembler
option is --gdwarf2 which is not the same as the GCC compiler option.
von Martin Thomas (Guest)
cognized
Maybe the rather old version (3.4.0) of the GNU-Toolchain causes the
problems which you describe in this and your other thread(s). Try to
update to a current version of the bintuils and gcc. If you run Linux on
a "standard PC" you can download a binary collection from codesourcery
and (?) from gnuarm. If you are using another "Unix" try to compile an
up-to-date source.
Martin Thomas
