Forum: ARM programming with GCC/GNU tools Atmel AT91 USB Framework
von Joe (Guest)
Has anyone ported the Atmel AT91 USB Framework to WinARM? (And would
like to share?)  It looks the primary work is converting the NMAKE
makefiles to WinARM-style makefiles.
If not, I'll give it a go.
The documentation and source for the framework is on this page:
http://www.atmel.com/dyn/products/app_notes.asp?family_id=605
- Joe
von Martin Thomas (Guest)
If have ported the USB Core + HID example to GNU:
http://www.siwawi.arubi.uni-kl.de/avr_projects/arm_projects/index_at91.html#at91_usb1
As written on the page the port is preliminary and there are still some
small incompatibilites with the makefiles and the shell (sh.exe) as
included in WinARM 6/06 (I already use a different sh.exe which will be
part of the next WinARM) but most of the work should be done. Tests of
the keyboard- and mouse-emulation with an AT91SAM7S-EK Board (with
AT91SAM7S64) have been succesfull.
Martin Thomas
von Joe (Guest)
It's not sh.exe, it's make.exe that appears to be the problem.  The make
distributed with WinARM 6/06 is version 3.80.  Try substituting make
3.81 that came with OpenOCD re100.
- Joe
The process:
Building startup.o ...
/usr/bin/sh: line 2: syntax error: unexpected end of file
make: *** [startup.o] Error 258
Very strange.  What is calling sh?  Without modifying your makefiles,
when I take sh.exe out of the path, it compiles without error.
After some poking around, I noticed that using "SHELL = cmd" does not
work as described in the make manual.  If you check it with $(warning
shell= $(SHELL)), make outputs "shell= c:/winarm/utils/bin/sh.exe".
When the winarm sh.exe is removed or renamed, make sets SHELL to simply
"sh.exe".  Actually, under MS-DOS, SHELL shouldn't even have to be
specified, because make is supposed to use the MS-DOS environment
variable "COMSPEC".  But I tried this and it does not.
Specifying SHELL = cmd.exe sets shell to "C:/WINDOWS/system32/cmd.exe".
However, that does not work either.  It appears that make is calling
cmd.exe with the -c switch, when it should be /c.  So this seems more
like a make.exe issue than a sh.exe issue.
[At this point I looked at the version of make and tried a newer
version, et voila! ]
Thanks for the detailed explanation.
I should have given more details in my first answer - sorry. Yes, the
older version of make as in WinARM 6/06 is the main reason for the
problem with the current makefiles. This is because it calls a
"Unix-Shell" with "Window-Shell" commands in the makefile. I have
suggested the workaround to rename sh.exe on the web-page since the user
does not need additional software (like a new version of make). There
are only some lines left in the makefiles of the USB-framework GNU-port
with depend on "cmd.exe"-syntax/functions, the best solution would be to
rewrite those lines to be "Unix-Shell" (bash or zsh) compatible. Then
the code will be compatible with older versions of make and can also be
built on non-Microsoft-hosts.
