Forum: ARM programming with GCC/GNU tools Error validating JTAG scan chain
von Lukas S. (Guest)
Hello!
I have build a JTAG adapter with a FT2232C and the layout from
http://www.fh-augsburg.de/~hhoegl/proj/usbjtag/usbjtag.html
The USB-Serial converter (Channel B) works fine, but when I try to use
OpenOCD
c:\Programme\openocd-2006re115\bin\openocd-ftd2xx.exe -f
c:\Programme\openocd-2006re115\bin\at91sam7s256-jtag.cfg
the TCK Pin goes low (pulled high with 47k) and remains low until I
disconnect the JTAG interface and OpenOCD returns this error:
Error:   jtag.c:1149 jtag_validate_chain(): Error validating JTAG scan
chain, IR mismatch, scan returned 0x3f
I've checked all connections but the problem remained :-(
My at91sam7s256-jtag.cfg File:
#define our ports
telnet_port 4444
gdb_port 3333
#commands specific to the Amontec JTAGKey
interface ft2232
ft2232_device_desc "Dual RS232 A"
ft2232_layout usbjtag
ft2232_vid_pid 0x0403 0x6010
jtag_speed 2
jtag_nsrst_delay 200
jtag_ntrst_delay 200
#reset_config <signals> [combination] [trst_type] [srst_type]
reset_config trst_and_srst srst_pulls_trst
#jtag_device <IR length> <IR capture> <IR mask> <IDCODE instruction>
jtag_device 4 0x1 0xf 0xe
#daemon_startup <'attach'|'reset'>
daemon_startup reset
#target <type> <endianess> <reset_mode> <jtag#> [variant]
target arm7tdmi little run_and_halt 0 arm7tdmi
#run_and_halt_time <target#> <time_in_ms>
run_and_halt_time 0 30
