Forum: ARM programming with GCC/GNU tools command-line programming utility
Author: Monk (Guest)
Hi all.
I hope you could help me. I need to find an utility which can download
(program) my .elf file to the hardware via JTAG (Wiggler).
Right now only possibility I have is to download using CrossWorks
Studio. But it doesn't really comfortable to program hundreds of devices
using GUI.. so I need to find something for command-line.
I have installed WinARM but it seems that there is no such program in
this kit. :( Or I have just missed it..
Thank you!
Author: Martin Thomas (Guest)
Which target? Search for OpenOCD which supports flash-programming for
various targets/families. If your target is supported: Use objcopy to
extract the machine-code from the elf-file into a "binary"-format file
(see the GNU binutils documentation). Transfer the content of the
binary-file with OpenOCD and the "Wiggler" to the target. Maybe useful:
http://www.siwawi.arubi.uni-kl.de/avr_projects/arm...
Martin Thomas
my target is str711. it seems that OpenOCD supports it. Unfortunately
I've overlooked it several times because everyone refers to this program
just as "debugger", and rarely someone notes that it has programming
ability, while I don't need a debugger.
thank you. Now I am in the middle of not-so-simple quest trying to
figure out what to write in configs and scripts of OpenOCD to make it
program my target properly..
Author: Michael Fischer (mifi)
Hello Monk,
Take a look here:
http://openfacts.berlios.de/index-en.phtml?title=O...
Here you will find some examples for the config files.
In the moment the server has some problems, Try it again later.
Or take a look here:
http://www.yagarto.de/howto/openocd/index.html
Here you can find a str7xx_pp.cfg file.
http://www.yagarto.de/download/openocd/str7xx_pp.cfg
I used this cfg only to debug in RAM, never try to
download into flash.
Best regards,
Michael
