Forum: ARM programming with GCC/GNU tools How to use newlib in ARM Projects?
von T_RAIN (Guest)
Hello everybody!
I'm very new to the ARM controllers. I'm currently working with an
ATSAM7 and the YAGARTO Toolchain.
The toolchain works fine but i'm missing functions like sprintf and
malloc!
I read that they are avialable at the newlib library. How do i include
this library into my code? I couldn't find any newlib directory in the
installation path of Yagarto.
Do i need special linker or complier flags when my code uses sprintf or
malloc functions?
Currently i got the folliwing error:
Code:
undefined reference to `malloc'
Tanks a lot
Greetings
T_RAIN
von Martin Thomas (Guest)
> Code:
Is this the complete message? Did you include <stdio.h>? Any message
about with "sbrk"? Did you search the forum for newlib, syscalls and
stdo? Please paste or attach the complete output from the build-process.
von T_RAIN (Guest)
Thanks for your reply:
Here is the complete output of the build process:
make -k all
...compiling main.c
arm-elf-gcc -I./ -c -fno-common -O0 -g main.c
...linking
arm-elf-ld -v -lc  -Map main.map -Tdemo_at91sam7_blink_flash.cmd -o
main.out crt.o  main.o lcd.o lowlevelInit.o debug.o libgcc.a
GNU ld version 2.17
main.o: In function `main':
I:\SOFTWARE\5.Semester\ARM_Projects\demo_at91sam7_blink_flash/main.c:49:
undefined reference to `printf'
make: *** [main.out] Error 1
make: Target `all' not remade because of errors.
This is the Makefile that i'm currently using:
#      Makefile for Atmel AT91SAM7S256 - flash execution
# * James P Lynch  September 3, 2006                            *
NAME   = demo_at91sam7_blink_flash
# variables
CC      = arm-elf-gcc
LD      = arm-elf-ld -v -lc
AR      = arm-elf-ar
AS      = arm-elf-as
CP      = arm-elf-objcopy
OD    = arm-elf-objdump
CFLAGS  = -I./ -c -fno-common -O0 -g
AFLAGS  = -ahls -mapcs-32 -o crt.o
LFLAGS  =  -Map main.map -Tdemo_at91sam7_blink_flash.cmd
CPFLAGS = --output-target=binary
ODFLAGS  = -x --syms
OBJECTS = crt.o  main.o lcd.o lowlevelInit.o debug.o
# make target called by Eclipse (Project -> Clean ...)
clean:
  -rm $(OBJECTS) crt.lst main.lst main.out main.bin main.hex main.map
main.dmp
#make target called by Eclipse  (Project -> Build Project)
all:  main.out
  @ echo "...copying"
  $(CP) $(CPFLAGS) main.out main.bin
  $(OD) $(ODFLAGS) main.out > main.dmp
main.out: $(OBJECTS) demo_at91sam7_blink_flash.cmd
  @ echo "...linking"
  $(LD) $(LFLAGS) -o main.out $(OBJECTS) libgcc.a
crt.o: crt.s
  @ echo "...assembling crt.s"
  $(AS) $(AFLAGS) crt.s > crt.lst
main.o: main.c  include\AT91SAM7X256.h include\board_ex256.h
include\registers.h include\lcd.h
  @ echo "...compiling main.c"
  $(CC) $(CFLAGS) main.c
lcd.o: lcd.c  include\AT91SAM7X256.h include\ext_registers.h
include\lcd.h include\bits.h
  @ echo "...compiling lcd.c"
  $(CC) $(CFLAGS) lcd.c
lowlevelInit.o: lowlevelInit.c include\AT91SAM7X256.h
  @ echo "...compiling lowlevelInit.c"
  $(CC) $(CFLAGS) lowlevelInit.c
debug.o: debug.c include\AT91SAM7X256.h include\board_ex256.h
include\lib_AT91SAM7XC256.h
  @ echo "...compiling debug.c"
  $(CC) $(CFLAGS) debug.c
and yes i inculded:
#include <stdio.h>
#include <stdlib.h>
to my main.c file
I got these error message when i'm using functions like printf, malloc,
sprintf...
Is the liggcc file the newlib library. If not please tell me where I can
find it  in the yagarto filestructure.
Thank's a lot
Greetings,
T_RAIN
Martin Thomas wrote:
>> Code:
von Tony (Guest)
T_RAIN wrote:
> Hello everybody!
> malloc!
> malloc functions?
> Code:
> Tanks a lot
> Greetings
> T_RAIN
Hi Both,
I have same kind of problem (almost started a new topic). I'm receiving
this error:
c:/winarm/bin/../lib/gcc/arm-elf/4.1.1/../../../../arm-elf/lib\libc.a(fr
eer.o):
In function `_malloc_trim_r':
mallocr.c:(.text+0x48): undefined reference to `_sbrk_r'
mallocr.c:(.text+0x64): undefined reference to `_sbrk_r'
mallocr.c:(.text+0x84): undefined reference to `_sbrk_r'
c:/winarm/bin/../lib/gcc/arm-elf/4.1.1/../../../../arm-elf/lib\libc.a(ma
llocr.o):
In function `_malloc_r':
mallocr.c:(.text+0x424): undefined reference to `_sbrk_r'
mallocr.c:(.text+0x4cc): undefined reference to `_sbrk_r'
I would like to use stdlib.h or otherwise I have to code many standard
functions by my self.
Br. Tony
von Michael F. (mifi)
Hello Tony,
take a look here:
http://www.sparkfun.com/cgi-bin/phpbb/viewtopic.php?t=5390&start=15
At the end you will find the solution.
Best regards,
Michael
