Forum: ARM programming with GCC/GNU tools Software protection and calibration on LPC2138
von Cem E. (cemer)
Hello,
I have two issues in my mind which need a solution sooner or later.
I am trying to activate the software protection on the lpc2138, i.e.
programming the flash 0x1fc with 0x87654321. I wonder what alternative
approaches there might be?
Also, what is your preferred way to embed the serial numbers and/or
calibration data into the flash area, after testing the board with the
production sw? Reprogramming whole sw takes alot time, compared to the
size of the changes.
Thanks
Cem
von Martin Thomas (Guest)
Use .org <address> followed by .word <"magic value"> in you
startup-Assembler file. And make sure the bootloader is accessable (BSL
and UART0-Pins)  ;-)
You can reserve a memory-sector for such data and program the
device-specific values received for example by UART using IAR-functions
to this page. Or use you programming-hardware (or maybe even the
bootloader) to write some binary data you create for each device to a
fixed address in flash memory.
Martin Thomas
