Forum: ARM programming with GCC/GNU tools arm-elf-gcc not found error message
Author: Tarun (Guest)
I am using, lpc2xxx controller arm7 core.
All of the sudden when i tried to compile my program using make in pn
editor i sdtarted facing the problem with error message exactly as
writen below...
kindly provide support on this. I have been doing this thing since last
many days. but today suddenly this problem started. I have tried
reinstalling WinARM
arm-elf-gcc: not found
make: *** [gccversion] Error 127
Author: Super Mario (techbuddy)
check to see if the path is proper in the PATH according to the
installation guidelines.
also check if some other applications such as ( GNUARM or Cygwin ) are
in the PATH. If yes, please remove them.
If you are using XP, please delete make*.* files in c:\windows\prefetch\
.. restart the computer.
Things might help.  (atleast it did for me )
Tutu
> Tutu
dear, cygwin not installed...
tried deleting make*.* files...
didnt work..
tell me about these  path settings.. and how can it happen when i have
been compiling it from last many days..
any ways assist for PATH settings..
Tarun
did u use another IDE while using WinARM ? The same problem occured to
me only when I used another IDE at the same time WinARM was installed.
When you have been compiling for many days, then it is unlikely that
your path settings are incorrect.
I dont know. Sorry
Tutu
Author: Jim Kaz (ancaritha)
It is unlikely to be your path settings since it was working previously,
but it can't hurt to double check them.  If you aren't sure how to do
this:
Right click on 'My Computer' and click on properties.  Click on the
'Advanced' tab, and then the Environment Variables button.  Under the
'System Variables' section there should be a variable called PATH.  It
should have  C:\WinARM\bin;C:\WinARM\utils\bin; in it.
