Forum: ARM programming with GCC/GNU tools Strange installation problem, Mic Win XP SP2
von Vikas (Guest)
I put the following lines in the System Path:
C:\WinARM\utils\bin;C:\WinARM\bin;
I cross check the system path by going typing make in the command prompt
and it recognises ( make.exe : please give make parameters )
When I type arm-elf-gcc on the command prompt it throws an error
cygwin1.dll not found. I saw on the website that the WInARM does not
depend on cygwin or mingw. Then why do I get this error ?
Also
From the pn.exe i select one of hte project and run make all
I get the following error.
make.exe: *** [gccversion] Error -1073741515
> Process Exit Code: 2
> Time Taken: 00:01
I have been struggling for the past 2 days  for this silly problem . Any
help would be a boon..
Thanks
Vikas
von Stefan (Guest)
Examine which EXE depends from cygwin1.dll with
http://www.ucware.com/apev/how-to-view-dll-dependencies.htm
Did you try another PATH too?
C:\WinARM\bin;C:\WinARM\utils\bin;
Stefan
von Stefan (Guest)
> Stefan
Add
http://www.dependencywalker.com/
von Vikas (Guest)
Does it matter if i write,
or
I think it should not be a problem. Nevertheless, I interchanged it
found the same problem. Regarding cygwin1.dll, I entered the cygwin/bin
Path in the PATH file and it works. But AFAIK WINArm does not depend on
cygwin. It is a standalone ! Do I need anything from Keil or other
properitary companies to evade this error.
> Time Taken: 00:01
von Martin Thomas (Guest)
> Also
>> Time Taken: 00:01
Are you sure that no other arm-elf cross-compiler or make-utility is
installed and entries for for this are in the search path? GNUARM comes
in mind since as far as I know the GNUARM-binaries depend on cygwin
(havn't used GNUARM since more than a year).
Use the Windows "find file": Start->Search->Files and Folders, search
for make.exe and arm-elf-gcc.exe. If you find files with these names in
other folders you may rename these folders so c:\winarm\utils\bin and
c:\winarm\bin are the only folders with the toolchains/utils "exe"s.
Martin Thomas
von Vikas (Guest)
Hi
I cant explain what fixed my problem, but I did the following after
Martins mail. found make.exe in the whole disk. and found 4 occasions ..
GNUARM/bin, DevCPP/bin,
Hitex/bin, cygwin/bin. Renamed all of them to _bin though I was sure,
there were no path in the system path. and it did not work. I got the
same problem as before. Then I found something called
c:\windows\prefetch\make-blahblah.exe and renamed those too.. I
retarted.. ! Everything works now.. I made everything as good as
before... and it still runs ..!!!
Thanks Martin, Stefan though for quick replies.
von Super M. (techbuddy)
Regarding my previous mail
please read
retarded as "restarted" :p
