Forum: ARM programming with GCC/GNU tools arning: passing argument from incompatible pointer type
Author: Joe (Guest)
I'm getting this error from WinARM:
Warning: passing argument 4 of 'AT91F_TWI_ReadByte' from incompatible
pointer type
with this code:
char read[5];
int AT91F_TWI_ReadByte(const AT91PS_TWI pTwi ,int mode, /
                         int int_address, char * data, int nb)
   some code here;
void main(void)
   AT91F_TWI_ReadByte(AT91C_BASE_TWI, LED_CONTROLLER0, 0x02, &read, 1);
What is incompatible with the pointer?
- Joe
Author: Martin Thomas (Guest)
1. Mistake in code, no reason to blame WinARM
2. warning != error
3. test with &read[0] or just read and try to understand the difference
to &read
4. use int main(void) to avoid another warning
5. read a C-book (i.e. Brian W. Kernighan and Dennis M. Ritchie, The C
Programming Language) or C-tutorial soon.
&read has type char** not char* you simply need just read on its own
which has type char[] which is compatible with char*, or &read[0] which
is a char*.
A char[] when passed as a function parameter always degrades to char* in
any case.
The only difference between a char* and char[] is the value of sizeof();
char read[10] ;
char* pRead = read ;
sizeof(read) == 10
sizeof(pRead) == 4 (on a 32bit architecture such as ARM)
Clifford
Author: Joe (Guest)
> is a char*.
Thanks Clifford.  The code is a sample from Atmel, so evidently they
don't know what they are doing either.  (By the way, the IAR compiler
doesn't issue any warnings in it's default setup.)
And Martin, I was in no way blaming WinArm!  I love WinARM!  I
appologise for calling the warning an error.
- Joe
