Forum: ARM programming with GCC/GNU tools Can't build WinARM samples on YAGARTO
von jdupre (Guest)
I am trying out the YAGARTO toolchain with Eclipse, but I can't get the
WinARM sample applications to compile.  Following is a snipet of the
errors I get with the BasicUSB sample project.
It appears that the makefile can't call the "echo" command.  Any idea
why this doesn't work under YAGARTO???
make -k all
process_begin: CreateProcess(NULL, echo, ...) failed.
make (e=2): The system cannot find the file specified.
make: *** [begin] Error 2
arm-elf-gcc (GCC) 4.1.1
Copyright (C) 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is
NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
PURPOSE.
make: *** [../compil/SrcWinARM/Cstartup.o] Error 2
make: *** [interrupt_Usart.o] Error 2
make: *** [../compil/SrcWinARM/Cstartup_SAM7.o] Error 2
make: *** [main.o] Error 2
make: *** [cdc_enumerate.o] Error 2
von Martin Thomas (Guest)
echo.exe is part of the WinARM "build-utilities" (standard location
c:\WinARM\utils\bin). I don't know if Yagarto includes this too. If you
don't have WinARM (or WinAVR) installed check
http://unxutils.sourceforge.net/ there is an echo.exe in one of the
archives. Place the file in the same directory as the make.exe installed
by Yagarto.
For a simple workaround you may just delete all "information lines"
which use echo from the makefile.
Martin Thomas
von jdupre (Guest)
> by Yagarto.
Yes, that seems to be the problem.  But why would I need echo.exe, when
echo is a built in DOS command?  (I can type in "@echo Print some text."
at the command line and it works fine.)
-Joe
von Scott K. (skirkpatrick)
>> by Yagarto.
> -Joe
Joe,
I had the same problem and figured out the solution.  Evidently Window's
echo command doesn't like a few things that the other version does.
This is what I did to fix the problem (although I'll probably get the
unxutils version):
1) Add a new MSG string
MSG_BLANK = " "
2) Change all blank echo lines '@echo' to '@echo $(MSG_BLANK)'   (ignore
single quotes)
3) Change all MSG strings to have double quotes at the begin and end of
the strings.
Scott
