Forum: ARM programming with GCC/GNU tools problem about 711's clock
von Weimin L. (afsim)
It is OK like this:
  RCCU_Div2Config(ENABLE);
  RCCU_MCLKConfig(RCCU_DEFAULT);
  RCCU_FCLKConfig(RCCU_RCLK_8);
  RCCU_PCLKConfig(RCCU_RCLK_8);
  RCCU_PLL1Config(RCCU_PLL1_Mul_12 , RCCU_Div_4) ;
  while(RCCU_FlagStatus(RCCU_PLL1_LOCK) == RESET);
  RCCU_RCLKSourceConfig(RCCU_PLL1_Output) ;
when i change
to
  RCCU_PLL1Config(RCCU_PLL1_Mul_12 , RCCU_Div_2) ;
code can't run.
so,MCLKval=24M is OK
MCLKval=48M is failure.
Is it a hardware problem?
MCLKval=RCCU_FrequencyValue (RCCU_MCLK);
APB1CLKval=RCCU_FrequencyValue (RCCU_FCLK);
APB2CLKval=RCCU_FrequencyValue (RCCU_PCLK);
thank you in advance.
von Spencer O. (ntfreak)
What clock are you driving the str7 with ?
Here ia an example of using a 16MHz clock input
RCCU_Div2Config( ENABLE );
RCCU_MCLKConfig( RCCU_DEFAULT );
RCCU_FCLKConfig( RCCU_RCLK_2 );
RCCU_PCLKConfig( RCCU_RCLK_2 );
RCCU_PLL1Config( RCCU_PLL1_Mul_12, RCCU_Div_2 );
RCCU_RCLKSourceConfig( RCCU_PLL1_Output );
This will give us a MCLK of 48MHz and a peripheral clock of 24MHz
I have noticed that when debugging the clocks can sometimes get locked
up.
If you have get this behaviour then insert the follwing before the clock
config above. This will reset the clock to the default state before
changing to the new clcok source.
RCCU_RCLKSourceConfig( RCCU_CLOCK2 );
Hope this helps.
Spen
von afsim (Guest)
Spen:
yes, i am using a 16MHz clock input.
so I think it is something wrong with hardware.
thank you very much indeed.
von afsim (Guest)
> up.
I try this today.
You are right.
add
before the clock config,my board can run at 48M.
Thank you very much indeed.
Note this should only need doing for debugging, when the device is reset
from cold then the RCCU_CLOCK2 option is enabled by default.
Some ide's use a reset script that perform similar behaviour to adding
this line.
Regards
Spen
