Forum: ARM programming with GCC/GNU tools Basic understanding of commands
von Stefan L. (stefanl38)
Hello,
im very new to ARM-GCC and c itself
so i have two very basic questions.
So "almost"-newbies have the pleasure to give an answer too.
what does the "~" do ?
example:
VICIntSelect &= ~0x00000040;
i was googling a lot but did not find anything at all
related to "c"
VICIntSelect is just a constant defined in the headerfile lpc2xxx.h
#define VICIntSelect   (*((volatile unsigned long *) 0xFFFFF00C))
das the commandline
VICIntSelect = 0x00000040;
mean: store value "0x00000040" in Memory-Adress "0xFFFFF00C" ?
thank you very much for helpful answers
greetings
Stefan
von Stefan (Guest)
~ (tilde) 1's complement
in German: "Komplementierung aller Bits eines Integer-Wertes
(NOT/Einer-Komplement)."
Examples:
~00000000 == 11111111
~11111111 == 00000000
~11001101 == 00110010
Links
http://www.schellong.de/c.htm#oper (German)
http://www.lysator.liu.se/c/bwk-tutor.html#bit
Yes.
Another Stefan ;-)
von Clifford S. (clifford)
> related to "c"
What did you googler on? Obviously typing '~' into google would not get
you far! Googling of "C Operators" would have got you the answer - as
would any good C reference (in fact even a bad reference!). Get yourself
a copy of K&R for example.
Clifford
>> related to "c"
> Clifford
Just for the record, this is the response this ilicited from Stefan by
privaed e-mail:
so you're just another one of this arrogant guys
throwing around special TLA*s like "K&R"
What if I even did not know that "~" is an OPERATOR?
judging about your answer: NOT HELPFUL AT ALL
just satisfying your frustration about what ever
I am sorry Stephan, if you found the response unhelpful. That was not
the intention. I felt that the specific question had been adequately
answered, so rather than duplicate the information I thought that
perhaps a better approach to problem solving than posting to a forum
might be helpful. Also the suggestion would have provided information on
all the other C operators as well. It is interesting that you found that
unhelpful.
It did not seem unreasonable to me that if you are going to use a
programming language that you should have some sort of language
reference. "The C Programming Language" by Kernighan and Ritchie (K&R)
is the seminal work on the language. It commonly referred to as K&R, and
Google'ing on just that will certainly tell you what it is if you were
not familiar.
If you did not realise that '~' was an operator, than you don't really
understand the syntax of C. All the more reason to get a reference.
von FordP (Guest)
Another suggestion if you find a search engine does not work for you, is
to head over to wikipedia which will always lead to a starting point to
find out about such things.
Good Luck with learning ANSI C, I have been using it for 18 years so I
think I have the hang of it now!
von FordP (Guest)
I took some of my own medcine and found this :-
http://en.wikipedia.org/wiki/Operators_in_C_and_C%2B%2B
Not bad for 5 clicks!
