Forum: ARM programming with GCC/GNU tools problems with lst
von Massimiliano C. (mastupristi)
I use WinARM from Yagarto (gcc 4.1.1)
I tried with this sample file:
int main(void)
  int a;
  a = 3;
  return 0;
compile with:
arm-elf-gcc -c  -mcpu=arm7tdmi  -I. -g3 -DROM_RUN  -Wall -Wcast-align
-Wcast-qual -Wimplicit  -Wpointer-arith -Wswitch -Wredundant-decls
-Wreturn-type -Wshadow -Wunused -Wa,-adhlns=dummy.lst  -I./include -MD
-MP -MF .dep/dummy.o.d -Wstrict-prototypes -Wmissing-declarations
-Wmissing-prototypes  -std=gnu99 dummy.c -o dummy.o
and dummy.lst is:
   1                  .file  "dummy.c"
  11                .Ltext0:
 243                  .align  2
 244                  .global  main
 246                main:
 247                .LFB2:
   1:dummy.c       **** int main(void)
   2:dummy.c       **** {
 248                e_needed = 1, uses_anonymous_args = 0
 249                  mov  ip, sp
 250                .LCFI0:
 251 0000 0DC0A0E1     stmfd  sp!, {fp, ip, lr, pc}
 252                .LCFI1:
 253 0004 00D82DE9     sub  fp, ip, #4
 254                .LCFI2:
 255 0008 04B04CE2     sub  sp, sp, #4
 256                .LCFI3:
 257 000c 04D04DE2     .loc 1 4 0
 258                  mov  r3, #3
   3:dummy.c       ****   int a;
   4:dummy.c       ****   a = 3;
 259                args = 0, pretend = 0, frame = 4
 260 0010 0330A0E3     @ frame_needed = 1, uses_anonymous_args = 0
 261 0014 10300BE5     mov  ip, sp
   5:dummy.c       ****   return 0;
 262                e  0x1
 263 0018 0030A0E3     .uleb128 0x1
   6:dummy.c       **** }...
 264                eb128 0x0
 265 001c 0300A0E1     .ascii  "__SOFTFP__ 1\000"
 266 0020 08A89DE8     .byte  0x1
 267                  .uleb128 0x0
 268                  .ascii  "__ARM_ARCH_4T__ 1\000"
 312                  .byte  0x1
DEFINED SYMBOLS
                            *ABS*:00000000 dummy.c
C:\DOCUME~1\MF9BB~1.CIA\IMPOST~1\Temp/ccA7aaaa.s:246    .text:00000000
main
C:\DOCUME~1\MF9BB~1.CIA\IMPOST~1\Temp/ccA7aaaa.s:251    .text:00000000
$a
NO UNDEFINED SYMBOLS
it seems that instruction and code are not aligned...
is this a bug?
thanks
von Martin Thomas (Guest)
> is this a bug?
The listing looks o.k. to me. What makes you thing that there is a bug?
von A.K. (Guest)
Left part (addresses, opcode) of the disassembly does not correspond to
right part (instructions). Lines appear to be shifted by 1, up to 260.
Beyond, it gets weirder.
von A.K. (Guest)
WinARM: The assembly listing is fine without -g<any>, but garbage with
debugging enabled.
GNUARM: Correct in both cases.
> debugging enabled.
is this a bug from gcc official tree?
Is this bug already be reported?
thanks
> debugging enabled.
how GNUARM have corrected this problem? Is there a patch to apply?
both WinARM and yagarto does not modify anything in the the source about
the "real" compiler. So I wonder how GNUARM can be correct if is based
on the same gcc sources.
thanks
von A.K. (Guest)
GNUARM and WinARM use different system emulation layers, cygwin vs mingw
or whatever. So source code could be identical, with the problem being
some unfortunate side effects of a less than perfect API emulation.
