Forum: ARM programming with GCC/GNU tools Problem getting fiq working with AT91SAM7S256
Author: Michel Boulanger (vbarre)
I have no problems with normal interrupts (irqs) but cannot get fast
interrupt (fiq) working. I am using the assembler wrapper code found in
the "MIPS" example. Looking at the wrapper code for fiq
(FIQ_Handler_Entry), I am wondering if it is complete : is it not
supposed to save the LR_fiq in fiq stack at the begining?
Has anybody tested successfully this wrapper ?
Thanks.
Michel
Author: Martin Thomas (Guest)
I don't think the wrapper itself does cause the problem. I have not used
ARM7 FIQ so far since I did not need it in a project -> I have not
tested the wrapper. But the wrapper seems to handle the "banked" LR
correctly and the LR is also "saved" on the stack before the wrapper
calls the user-function. You may check the stack-setup startup
assembler-code. The startup-code based on examples from Atmel do not
include the "MOV SP,..." for the FIQ stack-setup. The instructions used
for the other stack initialisations can serve as templates for the FIQ
stack-setup
Martin Thomas
