Forum: ARM programming with GCC/GNU tools Newbie: Insight-GDB, interrupts, & AT91SAM7S256
von Holger S. (fzippo)
Hello,
I was able to compile the at91sam7s_example_gamma_20060910b
example for my Olimex SAM7-P256 board into RAM, I even
suceeded in using SAM-BA (USB) to upload the binary.
I want to step through it with Insight, connected via ocdremote
and Olimex wiggler (connects nicely). However, Insight
would hang unless I comment out anything involving interrupts.
Sure, since these are my first steps on the new platform,
I know too little about ARM and GDB. I wonder whether such
debugging is impossible in principle, perhaps because GDB
uses software interrupts for breakpoints, or if this should be
possible in general.
Many thanks to Martin THOMAS for the excellent WinARM distribution,
regards,
Holger.#
von Martin Thomas (Guest)
Holger Schellwat wrote:
> Hello,
> regards,
> Holger.#
I expect the reason for your problem is that the core still expects the
exception-vectors at 0x0 but they are located at 0x00200000 for
"RAM_RUN".
In the RAM_RUN configuration of "gamma 20060610b" remapping is not
enabled by the startup-code. In my optionion it's the task of the
debugging-software to enabled remap (i.e. in a "debugger-script") before
setting PC to 0x00200000 so it's not enabled by default in "RAM_RUN".
Anyway: for a test you could try to replace
/*- Remapping
.if (VECTREMAPPED)
with
.if (1)
in startup.S so the remapping-code is alway included and executed at
startup.
Hope this helps,
Martin Thomas
