Forum: ARM programming with GCC/GNU tools Make
von Randall S. (rswaving)
How can I start lpc21isp from make?
Thnak you.
von Martin Thomas (Guest)
> Thnak you.
Examples how this can be configured are available in most (all) of the
Makefiles from the WinARM-Examples collection for LPC2xxx available in
examples-directory of the WinARM distribution-package or at
http://www.siwawi.arubi.uni-kl.de/avr_projects/arm_projects/index.html
(1)
Somewhere in a Makefile you can add some configuration-options as
"variables":
# Flash-Programming support using lpc21isp by Martin Maurer
# only for Philips LPC and Analog ADuC ARMs
# Settings and variables:
LPC21ISP = lpc21isp
LPC21ISP_PORT = com1
LPC21ISP_BAUD = 38400
LPC21ISP_XTAL = 12000
LPC21ISP_FLASHFILE = $(TARGET).hex
# other options:
# * verbose output: -debug
# * enter bootloader via RS232 DTR/RTS (only if hardware supports this
#   feature - see Philips AppNote): -control
LPC21ISP_OPTIONS = -control
#LPC21ISP_OPTIONS += -debug
(2)
Than add a program target to your makefile:
program: $(TARGET).$(IMGEXT)
--->$(LPC21ISP) $(LPC21ISP_OPTIONS) $(LPC21ISP_FLASHFILE)
$(LPC21ISP_PORT) $(LPC21ISP_BAUD) $(LPC21ISP_XTAL)
"--->" to be replaced by a tabulator. All $(LPC21ISP_*) in one line.
(3)
With this entries a make program will start lpc21isp with the given
parameters
Hope this helps,
Martin Thomas
