Forum: ARM programming with GCC/GNU tools trying to understand the link process
Author: outer_space (Guest)
Here are some excerpts from my .map file.  I'm using Cstartup.S v1.1
from atmel and Cstartup_SAM7.c v1.3 also from atmel.
*(.glue_7t)
*(.glue_7)
                0x00005e18                . = ALIGN (0x4)
What is in the .glue_7t and .glue_7 sections?  Where do they come from,
why are they there, what documentation is it described in?
Also I have an unrelated question about the mthomas hello world example.
Why does #include "lib_AT91SAM7S64.h" have to be commented out?  I see
that functions from this library are used but they are declared in the
board.h file by copy/pasting from lib_AT91SAM7S64.h.  Why didnt he just
include the library header rather than copy the declarations into
another file?
Author: Martin Thomas (Guest)
> *(.glue_7t)
> *(.glue_7)
As far as I know at least the interface-functions for interworking
generated internaly are placed in the glue-sections. It should be
documented in the binutils/ld-manual but I'm not sure. Also see the file
elf32-arm.c from the GNU binutils sources.
> another file?
I guess you mean the at91sam7s64_uart_simple-example. Yes, this has not
been well done - it's from the days when I started playing around with
the SAM7-eval-board. I have done some small updates now and the
"redundant" code has been removed, see
http://www.siwawi.arubi.uni-kl.de/avr_projects/arm...
Please check the AT91SAM7 "gamma"-example from the same page too -
newer, more options.
Martin Thomas
