Forum: ARM programming with GCC/GNU tools 40 ms to decode one mp3 frame
Author: Prashanth kumar (Guest)
   I am working with PXA270 processor. It takes nearly 40 ms to decode
one mp3 frame. I have enabled data cache as well as the instruction
cache. Please can you help me to reduce this decode time.
Regards,
 Prashanth kumar
Prashanth kumar wrote:
> Hi,
> Regards,
>  Prashanth kumar
Have you configured the system clock and SDRAM controller/memory timing
correctly? The chip will initialise at the crystal frequency (probably
as low as 12MHz!), with lowest common denominator 'safe' memory timings.
You configure and enable the clock multiplier and match the timings to
the memory parts on your board.
Clifford
Author: Prashanth Kumar (Guest)
>> Hi,
>> Regards,
>>  Prashanth kumar
> Clifford
   The details regarding to the memory clock and run mode clock are ,
P15 C0 reg = 107c
ccsr = 3000030e,
cccr_a, = 2000000
clkcfg = 3
Run Mode clock: 182.0MHz (*14)
Turbo Mode clock: 546.0MHz (*3.0, active)
Memory clock: 91.0MHz (/2)
Thank you
Ragards,
Prashanth Kumar
