Forum: ARM programming with GCC/GNU tools WinARM arm-elf-gcc generates incorrect bitfield code
Author: Jason Morgan (Guest)
This is related to the following thread on gcc bugzilla
http://gcc.gnu.org/bugzilla/show_bug.cgi?id=23623
Under certain conditions, the compiler generates ldrb instructions
instead of ldr.  These are incompatible with the ARM internal registers
and produce unpredictable results.
Is there any plan or existing project to fix this problem in WinARM.
This has probably been asked before, but the search on this forums is
broken at present.
Author: Martin Thomas (Guest)
According to the information on the gcc bugzilla the bug has been fixed
in the gcc sources in the CVS/SVN. Usualy I try to release a new
WinARM-collection shortly after a new stable release of gcc so the next
WinARM release should include a gcc which will be build from sources
where this problem is fixed.
Martin Thomas
