Forum: ARM programming with GCC/GNU tools arm-elf-gcc compiler toolchain with Newlib
Author: Tommaso Fedele (tommasof)
Hi, I want to compile the ARM MP3/AAC source code in cygwin. Which
version of arm-elf-gcc compiler toolchain with Newlib do you suggest?
Author: Martin Thomas (Guest)
Since you are using a Win32-OS: just try with GNUARM or WinARM (gcc
4.1.0/1, newlib 1.14). If you have problems you can ask here. IRC a
dummy-syscall had to be added to compile with WinARM just to make the
linker happy (the newlib configuration used for the WinARM-collection
does not provide the buildin newlib-syscalls, Andreas OSX-collection
does). But maybe Andreas has already added this to the current source in
the SVN.
Martin Thomas
Author: Tommaso (Guest)
> the SVN.
> Martin Thomas
Hi Martin,
I tried to download and configure gcc
> 4.1.0/1, newlib 1.14 from:
http://www.aps.anl.gov/epics/base/RTEMS/tutorial/node6.html
but my cygwin doesn't accept the command
patch -p1 <../ binutils-2.16.1-rtems-20050816.diff
to correct bugs. what do you suggest to do?
thanks tommaso
Author: Stefan (Guest)
Why not? No patch command/program or difficulties with the ' ' in the
commandline? Trouble with file locations?
Try patch -p1 < ../binutils-2.16.1-rtems-20050816.diff
and check the paths to files.
The manpage of patch says "The names of the files to be patched are
usually taken from the patch file"
Stefan
