Forum: ARM programming with GCC/GNU tools WinARM problem
von Aleš B. (ales)
I'm new to WinARM and I'm trying to compile the lpc2106_blink_switch
example in programmers notepad but the compiler gives this error out:
> "make.exe" clean
/c: /c: is a directory
make: *** [begin] Error 126
> Process Exit Code: 2
> Time Taken: 00:00
I don't know where or what the problem is. If someone know how to fix
this problem, please reply.
Thanks.
Ales
von Martin Thomas (Guest)
Aleš B. wrote:
> Hi,
>> "make.exe" clean
>> Time Taken: 00:00
If you are using the code that comes with the WinARM-package in the
examples-directory please verify that the PATH environement-variable is
set correctly. I have just tested the build and did not see a problem.
If you are using the source from my web-page please download it again, I
have just modified the makefile.
(direct link:
http://www.siwawi.arubi.uni-kl.de/avr_projects/arm_projects/#lpcio )
Martin Thomas
von Aleš B. (ales)
Martin Thomas wrote:
> Aleš B. wrote:
>> Hi,
>>> "make.exe" clean
>>> Time Taken: 00:00
> (direct link:
> Martin Thomas
I've fixed the problem, it works now.
Thanks Martin
von Sabkaraja (Guest)
What did you do? did you just set the path variable ?
cheers
> Thanks Martin
von Aleš (Guest)
Sorry that i didn't reply, so in the tools menu -> options -> tools i've
edit the path where the make.exe is located.
Before: [WinARM_G]Make All   make.exe   all
Now:    [WinARM_G]Make All   C:\WinARM\utils\bin\make.exe   all
