Forum: ARM programming with GCC/GNU tools help loading memory
von mk (Guest)
Hi all,
 Iam currently doing my final year project,porting jm10.1 code to arm7.i
have cross compiled the code to arm assembly using winarm tool
chain(arm-elf-gcc 4.1.0).Can any one tell me how to (test)load the
memory with test.264 bitstream.
Regards mk
von Clifford S. (clifford)
> Regards mk
How you load the code depends entirely on the target hardware you are
using (ARM is just a CPU core; it is used in a number of processors, all
with different architectures surrounding the core), and how you are
connecting to it (serial port, JTAG debugger etc.).
If you are using a commercial development board the board manufacturer's
web site is probably a good place to start for suitable tools and
documentation for programming the processor. Failing that the chip
vendors site may have tools for the specific chip.
Clifford
von mk (Guest)
>> Regards mk
  Before loading to the actual target i want to do simulation test using
arm sdt.
  The processor used is arm722t using jtag connector.can you please also
tell me    whether thee is any other environment(gnu) where i can
simulate the project.
Regards
mk
von mk (Guest)
Hi Clifford,
 The c code contains fprintf which reads the test bitstream.After
crosscompiling does the arm assembly code can read the file from the
disk or do i need to load the file contents to memory.
Regards
mk
mk wrote:
> Hi Clifford,
> Regards
> mk
I think I misunderstood. I thought you were asking how to load the
compiled program code to your target.
To be honest I now have no idea exactly what you are asking!
Clifford
von mk (Guest)
Hi Clifford,
I have to test the compiled code.The test data is contained in a *.264
file.The original c code uses fscanf to read the values.i want to know
whether the cross compiled code can read the test file or do i need to
load the test inputs to memory.
Regards
mk
von Dominic (Guest)
Unless you're using a debugger with semihosting capabilities you'll have
to download the test inputs to target memory. The ARM RealView tools
support semihosting iirc, i.e. you can use scanf, printf etc. on the
target, and the accesses are relayed through the debugger to the host
system.
You could either figure out how to include the .264 file directly with
the GNU tools, or use a script that converts your binary into a C array.
A quick search on google turned up this page:
http://www.chami.com/tips/delphi/052098D.html with a perl script that
converts binary files into C/C++ (among other languages) arrays. Just
compile that array, and link it with your code, and you should be able
to access the data from within your program.
Regards,
Dominic
If your system does not have a filesystem, then no.
It would not bee too difficult presumably to modify the code to read the
data at run-time over a serial port for example?
Clifford
von Andreas S. (andreas) (Admin)
mk wrote:
> Hi Clifford,
> Regards
> mk
You can use the file functions when you run the program in the simulator
(GDB/arm-elf-run).
Example:
http://www.mikrocontroller.net/attachment.php/372521/main.c
http://www.mikrocontroller.net/attachment.php/372522/newlib-syscalls.c
arm-elf-gcc -o test.elf -Os -g -mcpu=arm7tdmi main.c newlib-syscalls.c
arm-elf-run test.elf
von mk (Guest)
Andreas S. wrote:
> mk wrote:
>> Hi Andreas,
 I tried the file functions you specified.But whie linking iam getting
errors undefined refernce to _open,_close.
Regards
mk
mk wrote:
> Andreas S. wrote:
>> mk wrote:
>>> Hi Andreas,
Which toolchain are you using?
These functions are among the Newlib syscalls (see section 12 of
http://sources.redhat.com/newlib/libc.html). These are specific you your
target hardware and you are expected to implement them yourself.
Typically a minimal implementation will simply support the stdio streams
(stdout, stdin, and stderr), however you can use them to add support for
a filesystem or even emulate a filesystem over a serial or JTAG
connection for example - but you do need a good understanding of
iostreams and filesystems to make it work correctly. However, file I/O
will not 'magically' work, you have to provide the drivers (not to
mention having some sort of 'media'!).
If you have a COTS development board that is one of the ones for which
the WinARM distributuion has direct support, then it may already have a
minimal syscalls package that you can start with.
If you have no syscalls implementation, other parts of the standard
library will also fail. For example you will not have support for
dynamic memory allocation.
The simple answer is that file I/O is a DIY job for embedded systems,
because no system is the same - most do not even have filesystems. You
have been less than clear what your system has and how you expect this
date to be stored and delivered.
If you are expecting a host computer to serve the file data, then IMO it
would be much simpler in the short term for you to roll your own client
server architecture and deliver the data over serial or USB (serial
being by far the simpler, but much slower). A server application running
on the PC would accept data requests from a client running on the
target, and respond by sending the requested data. You'd need to define
your own protocol, it could be as simple or as complex as you need. Here
is where implementing the syscalls may be useful, for both stdio access
to the serial port and more importantly dynamic memory allocation, which
may be important if you need to allocate buffers for this data
Clifford
Newlib comes with default implementations that work with the simulator
exactly as I described above. But I recall now that Martin told me he
has compiled the Newlib for WinARM without the default syscalls because
his build would break otherwise.
Perhaps it is just me and everyone else knows what the following are;
jm10.1
arm7.i
test.264 bitstream
arm sdt
so that the responses from mk make more sense? I must admit that I am
not entirely clear what he is asking, and perhaps he has assumed that
the terms he is using are common place. As I said, perhaps they are, and
it is just me.
Clifford
von Martin Thomas (Guest)
It looks like the IO-Functions of the Simulator are implemented as
SWI-calls. See the implemention in the file libc/sys/arm/syscalls.c of
the newlib-sources (included in
WinARM/utils/useful_from_newlib_src.zip). I expect the simulator just
"traps" the SWI and passes it to the host's stdio-system. (So far I have
not used the armulator here). It should be rather easy to implement some
syscalls based on the newlib-source.
For the next release of WinARM I will try to make the "default-syscalls"
available again, since I personly don't need this functionality I did
not spend time to fix the issue I had during the build.
Martin Thomas
von Guest (Guest)
Hi all,
Is there any other method by which i can do this.I have heard that the
arm realview tools support semihosting which can read files from the
host system.Is ther any gnu debugger which can do this.
Thanks in advance
mk
von Dominic (Guest)
Guest wrote:
> Hi all,
> Thanks in advance
> mk
The GDB supports semihosting through it's remote protocol, but you'd
need a JTAG debugger which supports this together with the necessary
stubs on the target - I haven't heard of an open source solution which
supports this.
What's wrong with compiling the test data directly into your executable,
or on-demand loading it via serial?
Regards,
Dominic
