Forum: ARM programming with GCC/GNU tools Problem of debugging with eclipse + JLinkGDBServer
Author: Min Ge (minge519)
Hi All,
I got a problem of debugging with eclipse + JLinkGDBServer,
I used to work. But when I just added 4 lines code (The code has pass
debugging), then I can not run step by step.
When I download code and the cursur stop on the first line of my main
file.
But when I run Step Over or Step Into, it never came back.
If I took the 4 lines code, it works. The cod has not run to the 4 lines
yet.
BTW, I found the SP changes when I download the same code twice.
Sometimes it is 0x4f94, sometimes it is 0x20ff94. I always run in
RAM_RUN mode.
I do not know what is the problem. Could naybody help me? Thanks.
Min Ge
This thread from a few weeks ago suggests that Eclipse may not work
correctly with the WinARM GDB build.
http://en.mikrocontroller.net/topic/67396
Perhaps you need one of these:
http://www.cafepress.com/insaniteeshirts/1417922
Have you tried using the WinARM Insight debugger? If that fails as well,
then the problem may not them be with Eclipse.
Clifford
> RAM_RUN mode.
The ARM has separate SP registers for each processor mode. This will
happen if for example a data abort exception has occurred, and the
processor switches to ABORT mode. I have seen JTAG problems cause a
processor to be in an 'Undefined' mode state before.
Clifford
Author: Jim Kaz (ancaritha)
> Clifford
Woah... wait what?  WinARM Insight debugger?  Where can I get one of
these magical toys?  Today I installed Cygwin and i'm installing GDB
insight right now, but if I could get a magical WinARM one that'd be
fantastic :)
Hey, remember that time I asked about WinARM Insight?  Yea, google
reminded me that I am idiot, because its in the WinARM Readme :)
Yes, find it in the utils folder. The whole point of WinARM is surely so
you can avoid all the Cygwin nonsense!
