Forum: ARM programming with GCC/GNU tools str711 example code under gcc
von Mark Beauchemin (Guest)
  I'm trying to port the strp711 example code to gcc.  I believe it is
called buttons and leds.  Does anyone have a simple code example I could
get running with  on this platform?  The wiggler seems to be fine
running under openocd, but when I connect arm-elf-insight from winarm to
it, the load command blows up.  Bad build???
  Thanks,
    Mark
