Forum: ARM programming with GCC/GNU tools How to use Interrupt
Author: Min Ge (minge519)
Hi everyone,
I am trying to use Interrupt of AT91SAM7S256.
I read the example under WinARM. of at91sam7s64_Atmel_interrupt.
In file of Cstartup_SAM7.c, there have three functions
   - AT91F_Spurious_handler
   - AT91F_Default_IRQ_handler
   - AT91F_Default_FIQ_handler
But I can find ut the definition of those functions.
  Do I have to build those function by myself or I can get somewhere?
  How to use the 3 functions?
  How to use the functions to call different interrrpt handler files?
Thanks
Min Ge
Author: Jim Kaz (ancaritha)
Min Ge wrote:
> Hi everyone,
> Thanks
> Min Ge
I haven't worked with the S series, but I'm assuming that its similar to
the A3's.  Those three functions are default functions that don't do
anything.  They are handled in the assembly file.
To create your on interrupts, you have to to first enable what you want
to have interrupts, and then tell the main processor what to do with it.
The follow code is taking from the lib_AT91SAMA3 file that came with the
IAR example code.  I'm pretty sure the SAM7S has a similar file.
AT91F_AIC_ConfigureIt(AT91C_BASE_AIC, AT91C_ID_SYS,
EXTCOMM_INTERRUPT_PRIORITY, AT91C_AIC_SRCTYPE_INT_HIGH_LEVEL,
InterruptServicer::Interrupt_ID_SYS);
AT91F_AIC_EnableIt(AT91C_BASE_AIC, AT91C_ID_SYS);
The word 'InterruptServicer::Interrupt_ID_SYS' is the name of the
function you want this interrupt to call when it fires.  Then you just
have to write that function somewhere else, and it is automatically
executed when that interrupt fires.
'EXTCOMM_INTERRUPT_PRIORITY' is just a number (the priority of the
interrupt.
> interrupt.
Thanks a lot. I'll try.
Min Ge
>> interrupt.
Hi Jim,
I have designed and tested the interrupt as what you said. It is working
now.
Thanks a lot.
Min Ge
Glad I could be of service :)
