Forum: ARM programming with GCC/GNU tools Question about function of "AT91F_LowLevelInit()"
Author: Min Ge (minge519)
hI EVERYONE,
There is a funciton of "AT91F_LowLevelInit()" in Cstartup_SAM7.c.
Do I have to call this function in the beginning of my main() function?
I tried the two condition and can not tell the difference.
Min Ge
Author: Martin Thomas (Guest)
The function is used in the "Atmel-scheme" for startup-code. Atmel has
choosen a method to separate the startup in an assembler-part and a
C-part. This is rather convinient since as much as possible can be done
in C (the "Keil-Method" is to implement the startup in Assembler).
Additional the AT91-lib functions can be used. IRC the c-code sets up
the watchdog, system-clock and parts of the AIC so it is prefered to
call the function as early as possible.
If you'd like to follow the Atmel-Method look into the assembler-Code of
the examples which include a Cstartup.c. You will see at which stage the
function is called. For own developments: remind that a temporary stack
is set up before calling the c-Function, just use the examples as
templates.
Martin Thomas.
> templates.
> Martin Thomas.
Thanks a lot. I got it.
Min Ge
