Forum: ARM programming with GCC/GNU tools Error of "region CODE is full"
von Min G. (minge519)
hi everyone,
When I compile code with RAM_RUN (I use AT91SAM7S256)
I got the following error info.
Linking: main.elf
arm-elf-gcc -mthumb -mcpu=arm7tdmi -mthumb-interwork -I. -gstabs
-DRAM_RUN  -Os -Wall -Wimplicit  -Wpointer-arith -Wswitch
-Wredundant-decls -Wreturn-type -Wshadow -Wunused
-Wa,-adhlns=Cstartup.lst   -MD -MP -MF .dep/main.elf.d Cstartup.o
Cstartup_SAM7.o main.o arm_iop.o arm_spi.o arm_wdt.o U_hwdelay.o D_sd.o
H_FAT1632.o      --output main.elf -nostartfiles
-Wl,-Map=main.map,--cref -lc  -lm -lc -lgcc   -TAT91SAM7S256-RAM.ld
c:\winarm\bin\..\lib\gcc\arm-elf\4.1.0\..\..\..\..\arm-elf\bin\ld.exe:
region CODE is full (main.elf section .text)
section .text [00000000 -> 0000360f] overlaps section .rodata [00000000
-> 00000318]
section .data [0000031c -> 00000333] overlaps section .text [00000000 ->
0000360f]
main.elf: section .text lma 0x0 overlaps previous sections
make.exe: *** [main.elf] Error 1
Could naybody tell me how to get rid of the error? Thanks.
Min Ge
von Clifford S. (clifford)
> .text [00000000 -> 0000360f] overlaps section .rodata [00000000 -> 00000318]
> .data [0000031c -> 00000333] overlaps section .text [00000000 -> 0000360f]
See that your .text section occupies the same address space as .rodata
and .data. It is likely that your linker script (AT91SAM7S256-RAM.ld) is
incorrect.
Perhaps you should post the script.
Clifford
> incorrect.
> Clifford
I changed CODE and DATA size in "AT91SAM7S256-RAM.ld", it seems OK.
just post the file here:
// Srart of File
/*-         ATMEL Microcontroller Software Support  -  ROUSSET  -
/* The software is delivered "AS IS" without warranty or condition of
any    */
/* kind, either express, implied or statutory. This includes without
/* limitation any warranty or condition with respect to merchantability
or   */
/* fitness for any particular purpose, or against the infringements of
/* intellectual property rights of others.             */
/*- File source          : GCC_RAM.ld
/*- Object               : Linker Script File for RAM Workspace
/*- Compilation flag     : None
/*- 1.0 11/Mar/05 JPP    : Creation S256
//*** <<< Use Configuration Wizard in Context Menu >>> ***
// <h> Memory Configuration
//   <h> Code (Read Only)
//     <o>  Start <0x0-0xFFFFFFFF>
//     <o1> Size  <0x0-0xFFFFFFFF>
//   </h>
//   <h> Data (Read/Write)
//     <o2> Start <0x0-0xFFFFFFFF>
//     <o3> Size  <0x0-0xFFFFFFFF>
//   </h>
//   <h> Top of Stack (Read/Write)
//     <o4> STACK <0x0-0xFFFFFFFF>
//   </h>
// </h>
/* Memory Definitions */
MEMORY
  CODE (rx) : ORIGIN = 0x00000000, LENGTH = 0x00009000
  DATA (rw) : ORIGIN = 0x00009000, LENGTH = 0x00004000
  STACK (rw) : ORIGIN = 0x000d000,LENGTH = 0x00000000
/* Section Definitions */
SECTIONS
  /* first section is .text which is used for code */
  . = 0x0000000;
  .text : { *cstartup.o (.text) }>CODE =0
  .text :
    *(.text)                   /* remaining code */
    *(.glue_7t) *(.glue_7)
  } >CODE =0
  . = ALIGN(4);
  /* .rodata section which is used for read-only data (constants) */
  .rodata :
    *(.rodata)
  } >CODE
  . = ALIGN(4);
  _etext = . ;
  PROVIDE (etext = .);
  /* .data section which is used for initialized data */
  .data : AT (_etext)
    _data = . ;
    *(.data)
    SORT(CONSTRUCTORS)
  } >DATA
  . = ALIGN(4);
  _edata = . ;
   PROVIDE (edata = .);
  /* .bss section which is used for uninitialized data */
  .bss :
    __bss_start = . ;
    _bss_start_ = . ;
    *(.bss)
    *(COMMON)
  . = ALIGN(4);
  _bss_end_ = . ;
  _bss_end_ = . ;
  _end = .;
    . = ALIGN(4);
   .int_data :
   *(.internal_ram_top)
   }> STACK
  PROVIDE (end = .);
  /* Stabs debugging sections.  */
  .stab          0 : { *(.stab) }
  .stabstr       0 : { *(.stabstr) }
  .stab.excl     0 : { *(.stab.excl) }
  .stab.exclstr  0 : { *(.stab.exclstr) }
  .stab.index    0 : { *(.stab.index) }
  .stab.indexstr 0 : { *(.stab.indexstr) }
  .comment       0 : { *(.comment) }
  /* DWARF debug sections.
     Symbols in the DWARF debugging sections are relative to the
beginning
     of the section so we begin them at 0.  */
  /* DWARF 1 */
  .debug          0 : { *(.debug) }
  .line           0 : { *(.line) }
  /* GNU DWARF 1 extensions */
  .debug_srcinfo  0 : { *(.debug_srcinfo) }
  .debug_sfnames  0 : { *(.debug_sfnames) }
  /* DWARF 1.1 and DWARF 2 */
  .debug_aranges  0 : { *(.debug_aranges) }
  .debug_pubnames 0 : { *(.debug_pubnames) }
  /* DWARF 2 */
  .debug_info     0 : { *(.debug_info .gnu.linkonce.wi.*) }
  .debug_abbrev   0 : { *(.debug_abbrev) }
  .debug_line     0 : { *(.debug_line) }
  .debug_frame    0 : { *(.debug_frame) }
  .debug_str      0 : { *(.debug_str) }
  .debug_loc      0 : { *(.debug_loc) }
  .debug_macinfo  0 : { *(.debug_macinfo) }
  /* SGI/MIPS DWARF 2 extensions */
  .debug_weaknames 0 : { *(.debug_weaknames) }
  .debug_funcnames 0 : { *(.debug_funcnames) }
  .debug_typenames 0 : { *(.debug_typenames) }
  .debug_varnames  0 : { *(.debug_varnames) }
// End of File -----------------------------------------------------
Min Ge
So long as your memory usage is modest, that will work, but the script
dictates the exact locations and sizes of the STACK, CODE, and DATA
regions. This means that if  either section grows beyond the set length,
the link will fail even if there is otherwise plenty of RAM available.
It is more flexible to simply create a single RAM region and place all
the sections there, the linker will automatically place them
contiguously, so there are no large unused gaps, and the maximum amount
is then available for stack and heap growth. The STACK would normally be
placed as high as possible in RAM (since it grows downward). Unless you
are reserving that upper RAM region for something else, you might
consider placing it higher.
Clifford
Could you please tell me how to set RAM as flexible?
Min Ge
I am reluctant, since I'm not there with you ro debug it when it all
goes wrong! Keep a copy of your current script - just in case.
I am assuming that your sbrk() or sbrk_r() implementation places the
heap above the stack (at _end), so I propose that you place all the code
and data sections starting from zero, place the stack at some defined
position above the last code/data section (fixed size stack) leaving the
rest for heap. You choose the stack size - your current script allows
the data section to grow to the point where there would be little or no
available stack without warning!
Define the memory layout thus:
MEMORY
  RAM (rw) : ORIGIN = 0, LENGTH = 64K
STACK_LENGTH = 4K ;
Now replace all the instances of >CODE or >DATA with >RAM
To set the stack top change the lines:
   .int_data :
   }> STACK
to:
   . += STACK_LENGTH ;
   .int_data :
   } >RAM
I strongly suggest that you create a map file for your build to ensure
that everything is located as expected, and to determine how much heap
you will have available (everything above _end).
If you do not require much heap (used by malloc() and similar functions
as well as the C++ new operators, and internally within C++ container
classes for example), then you might want to make your stack much larger
to minimise the chance of it clashing with your static data or code.
Remember that library functions such as printf() use a considerable
amount of stack space. The 4K I have used in the example is very
conservative, but should just about support printf(). You need to
consider the requirements of your application and set it accordingly.
Clifford
> MEMORY
> STACK_LENGTH = 4K ;
>    .int_data :
>    }> STACK
> to:
>    . += STACK_LENGTH ;
>    .int_data :
>    } >RAM
I have tried. It works. Thanks a lot.
Min Ge
Wow, that's good luck - things usually break when I fiddle with linker
scripts! ;)
If your original script was one supplied as a WinARM sample, then
perhaps Martin might consider making this change to the distribution.
However, there may have been a good reason for it being the way it was.
Clifford
> scripts! ;)
> Clifford
Hi Clifford,
I am so sad of telling you. The file of "AT91SAM7S256-RAM.ld" I modified
does not work properly all the time. Sometimes it can not run to the
breakpoint I set. I tried on the original RAM file on the same code, it
owrks.
Must be something I have not modified correctly yet. I will check that
later and then tell you.
Thanks.
Min Ge
Min Ge wrote:
> Hi Clifford,
> owrks.
Possibly the stack allocation is too small. If this overflows it will
corrupt the code/data space. In the previous script the stack was
probably set much higher.
Clifford
