Forum: ARM programming with GCC/GNU tools Inline assembly
von Kumar K. (keir)
Hi all
I have to inline some arm instructions with c code.Can any one tell me
how to pass the parameters from c code to assembly and take the output.I
have a loop in the assembly code and the results are to be stored back
to an array in the c code.
Can any one suggest me any documents regarding this or any methods to do
it.
Regards
keir
von Stefan (Guest)
von Stefan (Guest)
von Kumar K. (keir)
Stefan wrote:
> Assembler Instruction Set for ARM
> http://www.heyrick.co.uk/assembler/qfinder.html
> http://www.arm.com/pdfs/QRC0001H_rvct_v2.1_arm.pdf
> http://www.arm.com/pdfs/QRC0007_VFP.pdf
hi all,
Thanks for the details
I have heard that assembly "*.s" file can be embedded in the c source
file and the assembly routine can be called fromm the c source.Can u
please send me the details of how to do that ie passing the parameters
to assembly code and getting the outputs.
kk
von Stefan (Guest)
Ask whoever told you this. I think this is not possible.
You can create pure assembler source files (*.s files)
You can create assembler source files that require CPP processing (*.S
files).
You can create c source files with inline assembler statements (see
above and more ARM specific:
http://www.ethernut.de/en/documents/arm-inline-asm.html).
Each of them may compile to an object file. The linker forms a binary
executable from these object files. So a mixture of object files from
*.s, *.S and *.c is possible.
More infos about stack layout and calling conventions:
http://www.cs.umbc.edu/~chang/cs313.s02/stack.shtml
