I have placed a test-version with gcc 4.1.1 in http://www.siwawi.arubi.uni-kl.de/avr_projects/arm... (File WinARM_20060531_pre.zip) In the gcc-Sources used to build the pex-win32 file has been replaced by a version from the CVS (it has not been part of the official 4.1.1-release). This hopefully fixes the problems in Win9X. So far I have not seen a side-effect on WinXP, so the patch should not break the NTff compatibility. So far the prerelease does not include any insight or command-line gdb. This is still "work in progress". Win9X-Users: please test and send feedback. Feedback from non-Win9x-Users is of cause welcome too. Martin Thomas
Martin, fine work! Got this pre version running. No problem with gcc calling the assembler like last time. Now i have just one small problem with the final linker run, when i make a binary for ROM. Building for RAM is OK. But not yet tested on the target because i have only little time until mid of next week and i can not dig too far into this until then. The error for the ROM build is: =============================== > "make.exe" all -------- begin -------- arm-elf-gcc (GCC) 4.1.1 (WinARM) Copyright (C) 2006 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. Assembling: startup.S arm-elf-gcc -c -mcpu=arm7tdmi -I. -x assembler-with-cpp -DROM_RUN -Wa,-adhlns=startup.lst,-gstabs startup.S -o startup.o Compiling: main.c arm-elf-gcc -c -mcpu=arm7tdmi -I. -gstabs -DROM_RUN -O0 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=main.lst -std=gnu99 -MD -MP -MF .dep/main.o.d main.c -o main.o Linking: main.elf arm-elf-gcc -mcpu=arm7tdmi -I. -gstabs -DROM_RUN -O0 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=startup.o -std=gnu99 -MD -MP -MF .dep/main.elf.d startup.o main.o --output main.elf -nostartfiles -Wl,-Map=main.map,--cref -lc -lm -lc -lgcc -TAT91R40008-NavMe-ROM.ld d:/winarm/bin/../lib/gcc/arm-elf/4.1.1/../../../../arm-elf/bin/ld.exe: address 0x1000900 of main.elf section .stack is not within region SRAM collect2: ld returned 1 exit status make.exe: *** [main.elf] Error 1 > Process Exit Code: 2 > Time Taken: 00:02 This is the critical section in main.map: ========================================= Discarded input sections .stabstr 0x00000000 0x0 startup.o .stabstr 0x00000000 0x0 main.o Memory Configuration Name Origin Length Attributes SRAM 0x00000000 0x00040000 rw ROM 0x01000000 0x00800000 xr RAM 0x03000000 0x00400000 rw default 0x00000000 0xffffffff Linker script and memory map LOAD startup.o LOAD main.o LOAD d:/winarm/bin/../lib/gcc/arm-elf/4.1.1/../../../../arm-elf/lib\libc.a LOAD d:/winarm/bin/../lib/gcc/arm-elf/4.1.1/../../../../arm-elf/lib\libm.a LOAD d:/winarm/bin/../lib/gcc/arm-elf/4.1.1/../../../../arm-elf/lib\libc.a LOAD d:/winarm/bin/../lib/gcc/arm-elf/4.1.1\libgcc.a START GROUP LOAD d:/winarm/bin/../lib/gcc/arm-elf/4.1.1\libgcc.a LOAD d:/winarm/bin/../lib/gcc/arm-elf/4.1.1/../../../../arm-elf/lib\libg.a LOAD d:/winarm/bin/../lib/gcc/arm-elf/4.1.1/../../../../arm-elf/lib\libc.a END GROUP 0x00000400 STACK_SIZE = 0x400 .text 0x01000000 0x4bc *startup.o(.text) .text 0x01000000 0x170 startup.o 0x01000150 reset 0x01000000 _boot 0x010000d4 _mainCRTStartup 0x01000150 abort 0x010000d4 _start 0x01000150 _reset 0x01000150 exit 0x010000d4 start *(.text) .text 0x01000170 0x32c main.o 0x010003f8 main *(.rodata) .rodata 0x0100049c 0x20 main.o *(.rodata*) *(.glue_7) .glue_7 0x010004bc 0x0 startup.o .glue_7 0x010004bc 0x0 main.o *(.glue_7t) .glue_7t 0x010004bc 0x0 startup.o .glue_7t 0x010004bc 0x0 main.o 0x010004bc . = ALIGN (0x4) 0x010004bc _etext = . 0x010004bc PROVIDE (etext, .) .data 0x00000000 0x0 load address 0x010004bc 0x00000000 _data = . *(.data) .data 0x00000000 0x0 startup.o .data 0x00000000 0x0 main.o 0x00000000 . = ALIGN (0x4) 0x00000000 _edata = . 0x00000000 PROVIDE (edata, .) .bss 0x00000000 0x0 0x00000000 __bss_start = . 0x00000000 _bss_start_ = . *(.bss) .bss 0x00000000 0x0 startup.o .bss 0x00000000 0x0 main.o *(COMMON) 0x00000000 . = ALIGN (0x4) 0x00000000 . = ALIGN (0x4) 0x00000000 _bss_end_ = . 0x00000000 PROVIDE (__bss_end, .) .stack 0x01000500 0x400 0x01000900 . = (. + STACK_SIZE) fill 0x01000500 0x400 00 0x01000900 PROVIDE (_stack, .) 0x01000900 _end = . 0x01000900 PROVIDE (end, .) .stab 0x00000000 0x75c *(.stab) .stab 0x00000000 0x3a8 startup.o .stab 0x000003a8 0x3b4 main.o 0x3c0 (size before relaxing) .stabstr 0x00000000 0x307 *(.stabstr) .stabstr 0x00000000 0x307 startup.o <...rest (symbols) snipped...> I checked the linker script file, but i can not detect a error. Here is my AT91R40008-NavMe-ROM.ld file ======================================= /************************************************************************/ /* */ /* ROM.ld: Linker Script File */ /* */ /* v0.1 - Stefan - 1st version for GNUARM & AT91R40008 on NavMe board */ /* Toolchain is GNUARM 4.1.0 */ /* written with teachings from WinARM example code */ /* */ /************************************************************************/ ENTRY(_boot) STACK_SIZE = 0x400; /* Memory Definitions */ MEMORY { SRAM (rw) : ORIGIN = 0x00000000, LENGTH = 0x00040000 ROM (rx) : ORIGIN = 0x01000000, LENGTH = 0x00800000 RAM (rw) : ORIGIN = 0x03000000, LENGTH = 0x00400000 } /* Section Definitions */ SECTIONS { /* first section is .text which is used for code */ .text : { *startup.o (.text) /* Startup code */ *(.text) /* remaining code */ *(.rodata) /* read-only data (constants) */ *(.rodata*) *(.glue_7) *(.glue_7t) } > ROM . = ALIGN(4); _etext = . ; PROVIDE (etext = .); /* .data section which is used for initialized data */ .data : AT (_etext) { _data = .; *(.data) } > SRAM . = ALIGN(4); _edata = . ; PROVIDE (edata = .); /* .bss section which is used for uninitialized data */ .bss (NOLOAD) : { __bss_start = . ; _bss_start_ = . ; *(.bss) *(COMMON) . = ALIGN(4); } > SRAM . = ALIGN(4); _bss_end_ = . ; PROVIDE (__bss_end = .); .stack ALIGN(256) : { . += STACK_SIZE; PROVIDE (_stack = .); } > SRAM _end = . ; PROVIDE (end = .); /* Stabs debugging sections. */ .stab 0 : { *(.stab) } .stabstr 0 : { *(.stabstr) } .stab.excl 0 : { *(.stab.excl) } .stab.exclstr 0 : { *(.stab.exclstr) } .stab.index 0 : { *(.stab.index) } .stab.indexstr 0 : { *(.stab.indexstr) } .comment 0 : { *(.comment) } /* DWARF debug sections. Symbols in the DWARF debugging sections are relative to the beginning of the section so we begin them at 0. */ /* DWARF 1 */ .debug 0 : { *(.debug) } .line 0 : { *(.line) } /* GNU DWARF 1 extensions */ .debug_srcinfo 0 : { *(.debug_srcinfo) } .debug_sfnames 0 : { *(.debug_sfnames) } /* DWARF 1.1 and DWARF 2 */ .debug_aranges 0 : { *(.debug_aranges) } .debug_pubnames 0 : { *(.debug_pubnames) } /* DWARF 2 */ .debug_info 0 : { *(.debug_info .gnu.linkonce.wi.*) } .debug_abbrev 0 : { *(.debug_abbrev) } .debug_line 0 : { *(.debug_line) } .debug_frame 0 : { *(.debug_frame) } .debug_str 0 : { *(.debug_str) } .debug_loc 0 : { *(.debug_loc) } .debug_macinfo 0 : { *(.debug_macinfo) } /* SGI/MIPS DWARF 2 extensions */ .debug_weaknames 0 : { *(.debug_weaknames) } .debug_funcnames 0 : { *(.debug_funcnames) } .debug_typenames 0 : { *(.debug_typenames) } .debug_varnames 0 : { *(.debug_varnames) } } Bye Stefan
Perhaps it's a problem with .stack, because .data and/or .bss are empty? I should try this with another example with data/bss variables.
Stefan wrote: > Perhaps it's a problem with .stack, because .data and/or .bss are empty? > I should try this with another example with data/bss variables. Found something in the WINARM Readme Version 8/2005 -> Version 20060116. Will check this out with WinARM and GNUARM as soon as possible. ==== It seems that the linker does not provide a correct "." if the section before is empty and the current section is aligned in the section "header". I'm not sure why - maybe a new feature or a bug in the binutils. In the "blinkswitch" examples for LPC2106 und LPC2129 I've somehow fixed this and verified the correct result by the values given in the map-file. In the linker-script for ROM .stack ALIGN(256) : { ... has been replaced with: .stack : { . = ALIGN(256); ==== I took some old WinARM linker script and modified it for GNUARM 4.1.0 (which doesn't throw this error).
I don't understand this. Test #1 with a dummy variable in main.c and therefore a non empty .data section => No linker error. Good main.map. Test #2 with suggestion from WinARM readme with other description of .stack section in the linker control script => No linker error. Good main.map. And then test #3 with unmodified original linker command script from yesterday (copyied version). All other files also unmodified => No linker error. Good main.map.
Made a fault and had an old main.c with dummy variable. Test #3 is same as yesterday. Now i'll use a changed linker script file just as suggested in the Winarm readme.
Thank you Stefan for the testing. I'm glad it's now working for Win98 too. About your linker-script issues: I do not know the exact explanation for this so I have mentioned the "workaround" in the readme-file. Martin Thomas
Martin Thomas wrote: > Thank you Stefan for the testing. I'm glad it's now working for Win98 > too. About your linker-script issues: I do not know the exact > explanation for this so I have mentioned the "workaround" in the > readme-file. > > Martin Thomas It's a bug in ld http://www.mail-archive.com/bug-binutils@gnu.org/m... But it is marked as Status: RESOLVED Resolution: FIXED in http://sourceware.org/bugzilla/show_bug.cgi?id=1353 => http://sources.redhat.com/ml/binutils-cvs/2005-09/...
