Forum: ARM programming with GCC/GNU tools more lwip FreeRTOS 7x256 problems: "region full"
von Lars P. (lpaape)
With the hints from this forum (missing system calls) I got my toolchain
to
compile the project.  However the linker runs into an error with the
linker script
"region full".
(256k Flash, 64k Ram -> which also works fine for my other project).
Looks like
7xk are needed :(
Did anyone get the application running on a SAM7X256 with the sources
available from FreeRTOS?
Using WinARM or Cygwin/GNUARM did produce the same errors...
My own sample application works fine... any ideas...?
Thanks!
von Martin Thomas (Guest)
> to
> linker script
> "region full".
> Looks like
> 7xk are needed :(
- Which region is full?
- Memory-configuration in linker-script correct?
- Compiled with -Os?
- Compiled the non-ISR-code with Thumb/Thumb-Interwork?
Martin Thomas
Martin Thomas wrote:
Hi Thomas
region ram is full (rtosdemo.elf section .bss)
MEMORY
        flash   : ORIGIN = 0x00100000, LENGTH = 256K
        ram             : ORIGIN = 0x00200000, LENGTH = 64K
rest as in atmel-rom.ld
yes...
i've used the regular makefile, coming with the freertos sources ?
... no more clues from side... thanks
Lars Paape
Maybe the config/makefile options are set for "run from RAM" so code and
data is placed in the RAM. Check the used linker-script the sequence
after .text { ends with ">ram" if yes, try to change it to ">flash".
Martin Thomas
