Forum: ARM programming with GCC/GNU tools gdb crash in eclipse
Author: Jörg (Guest)
I got OpenOCD (6.2) running with my STR711, when using
gdb (codesourcery 6.3.5) from the command line.
Eclipse calls gdb with the strange MII ? syntax commands.
The gdb delivered with WinARM seems to be offended by this,
and crashes on the load command.
I tested the version that comes with sarm (from anglia) and it works!
They use cygwin of course :-(
Any experiences with gdb and eclipse around?
Regards,
Jörg
Author: Michael (Guest)
Jörg wrote:
> Hi,
> Regards,
> Jörg
Hello Jörg,
I have made the same experience with gdb that was based on MinGW.
No one is working correct if I have a MinGW based compiler. Only the
GNUARM toolchain is working. Take a look here:
http://www.usbdip.de/en/armdev/index.html
and at part 2.
Regards,
Michael
Hello Michael,
Hm I wonder whats the reason for this.
Do you think it has something to do with MinGW / Cygwin?
GDB and OpenOCD talk with each other over TCP/IP so there should
be no problem.
> Take a look here:
Yes, I already read your tutorial.
Seems like I got RAM/ROM-Debugging and FLASH programming
running with OpenOCD and Eclipse for STR71X.
Maybe I send you my files so you could have a look at
and put it on your site?
Regards,
Jörg
Hello Jörg,
> Regards,
> Jörg
In the moment I have no example for debug in ROM, therefore
it is a good idea, if I can get your example.
Regards,
Michael
