Forum: ARM programming with GCC/GNU tools Problem with malloc (WinARM, GCC 4.0.2)
Author: Vyachwslav Krutov (doomer)
I can't build the program with memory allocation functions thats work
correctly.
I definded _sbrk() and _sbrk_functions, but malloc returns zero-pointer,
or getting stick in after second call of _sbrk_r().
CPU - LPC2214
i tried to compile syscalls.c in pure arm mode and in thumb-interwork,
but result is same
----------------syscalls.c cut------------------------------------
 extern char _end;
 caddr_t _sbrk(int incr)
     HalDebugInfo("sbrk\n");
     static unsigned char *heap_end =0;
     unsigned char *prev_heap_end=0;
     if( heap_end == 0 ) heap_end = (caddr_t)&_end;
     prev_heap_end = heap_end;
     heap_end += incr;
     return(caddr_t) prev_heap_end;
void *_sbrk_r(struct _reent* reent, ptrdiff_t incr)
  return _sbrk(incr);
Whats version of libc should i use ?
..\arm-elf\lib\interwork\libc.a           // the program get stack in
after
                                          // second _sbrk_r call
..\arm-elf\lib\thumb\interwork\libc.a     // malloc always return zero
pointer
..\arm-elf\lib\be\interwork
..\arm-elf\lib\be\nofmult
Does anybody has a working code for memory functions ?
Author: Martin Thomas (Guest)
There is working code for sbrk in the newlib-lpc, source comes with
WinARM  in utils/newlib_lpc_src/. In other examples sbrk is implemented
in the file syscalls.c (basicly code from newlib-lpc or the
newlib-default-code or from Keil-Examples - it my differ a little bit).
Also check if end is provided correctly in the linker-script.
Martin Thomas
