Forum: ARM programming with GCC/GNU tools Support for Philips LPC2124??
von Randall Aiken (Guest)
Does WinARM support the Philips LPC2124 device?  If so, how do I go
about setting up the makefile to recognize it?
Thanks!
Randall Aiken
von Martin Thomas (Guest)
The arm-elf GNU-Toolchain as included in WinARM supports ARM7TDMI like
the LPC2129. You may start with an example for the LPC2129, ignore the
name of the linker-files and the SUBMDL-entry in the makefile first.
Just adjust the memory-sizes for Flash/ROM and RAM. The startup-code for
the LPC2129 (and most other LPCs) should work for the LPC2124 too.
If it works you can rename the linker-files to LPC2124[...].ld and
change the SUBMDL entry in the makefile. As you can see the SUBMDL-entry
in the makefile is just used to determine the name of the linker-file.
Martin Thomas
Thanks for the fast reply!  I tried that and it seems to compile and
link, so now I will test it on the target board.  I have a couple of
other questions, but I'll ask them under a new topic name.
Thanks!
Randall Aiken
> Thanks!
> Randall Aiken
Okay, it looks like everything is fully functional, including the UARTs,
I2C, SPI, and interrupts, so the Philips LPC2124 indeed works fine with
WinARM, in case anyone else is thinking of using it.
Randall Aiken
Thank's for your feedback.
Martin Thomas
von Steven (Guest)
Hello All,
I have been using an Olimex LPC-PC2124 with Eclipse and J-Link EDU for a
while now. I've only installed the OLIMEX GCCFD from the CD and added
the debugging settings. Everything was working fine until I started
using the FatFs - FAT file system module (R0.08b).
When I compiled the FatFs I received a -udivsi3 error. Found out it was
a floating point problem and was able to fix it using the Makefile from
Chan's example project folder.
Now I get "cannot find entry symbol_start; defaulting to 00008000". I
haven't had to change my Makefile until now so I'm not sure what to do.
Could someone please take a look at my Makefile and tell me what I am
doing wrong?? Any help is appreciated.
Thanks,
Steven
# Hey Emacs, this is a -*- makefile -*-
# WinARM template makefile
# by Martin Thomas, Kaiserslautern, Germany
# <eversmith@heizung-thomas.de>
# based on the WinAVR makefile written by Eric B. Weddington, Jöòg Wunsch, et al.
# Released to the Public Domain
# Please read the make user manual!
# On command line:
# make all = Make software.
# make clean = Clean out built project files.
# (TODO: make filename.s = Just compile filename.c into the assembler code only)
# To rebuild project do "make clean" then "make all".
# Changelog:
# - 17. Feb. 2005  - added thumb-interwork support (mth)
# - 28. Apr. 2005  - added C++ support (mth)
# - 29. Arp. 2005  - changed handling for lst-Filename (mth)
# -  1. Nov. 2005  - exception-vector placement options (mth)
# - 15. Nov. 2005  - added library-search-path (EXTRA_LIB...) (mth)
# -  2. Dec. 2005  - fixed ihex and binary file extensions (mth)
# - 22. Feb. 2006  - added AT91LIBNOWARN setting (mth)
30
# - 19. Apr. 2006  - option FLASH_TOOL (default lpc21isp); variable IMGEXT (mth)
31
# - 23. Jun. 2006  - option USE_THUMB_MODE -> THUMB/THUMB_IW
32
# -  3. Aug. 2006  - added -ffunction-sections -fdata-sections to CFLAGS
33
#                    and --gc-sections to LDFLAGS. Only available for gcc 4 (mth)
34
# -  4. Aug. 2006  - pass SUBMDL-define to frontend (mth)
35
# - 11. Nov. 2006  - FLASH_TOOL-config, TCHAIN-config (mth)
36
# - 28. Mar. 2007  - remove .dep-Directory with rm -r -f and force "no error"
37
# - 24. Aprl 2007  - added "both" option for format (.bin and .hex)
38
39
# Toolchain prefix (i.e arm-elf -> arm-elf-gcc.exe)
40
41
# -  2. Oct. 2008  - Changed for example project of FatFs moddule (chan)
42
43
44
# MCU name and submodel
45
MCU      = arm7tdmi-s
46
THUMB_MODE = NO
47
SUBMDL   = LPC2124
48
49
50
# Target file name (without extension).
51
TARGET = main
52
53
# List C source files here. (C dependencies are automatically generated.)
54
# use file-extension c for "c-only"-files
55
SRC =  main.c
56
57
# List C source files here which must be compiled in ARM-Mode.
58
59
SRCARM =
60
61
# List Assembler source files here.
62
# Make them always end in a capital .S.  Files ending in a lowercase .s
63
# will not be considered source files but generated files (assembler
64
# output from the compiler), and will be deleted upon "make clean"!
65
# Even though the DOS/Win* filesystem matches both .s and .S the same,
66
# it will preserve the spelling of the filenames, and gcc itself does
67
# care about how the name is spelled on its command-line.
68
ASRC =
69
70
# List Assembler source files here which must be assembled in ARM-Mode..
71
ASRCARM = crt.S
72
73
## Output format. (can be ihex or binary or both)
74
## (binary i.e. for openocd and SAM-BA, hex i.e. for lpc21isp and uVision)
75
FORMAT = both
76
77
# Optimization level, can be [0, 1, 2, 3, s].
78
# 0 = turn off optimization. s = optimize for size.
79
# (Note: 3 is not always the best optimization level. See avr-libc FAQ.)
80
OPT = -s
81
82
## Using the Atmel AT91_lib produces warning with
83
## the default warning-levels.
84
## yes - disable these warnings; no - keep default settings
85
#AT91LIBNOWARN = yes
86
AT91LIBNOWARN = no
87
88
# Debugging format.
89
# Native formats for AVR-GCC's -g are stabs [default], or dwarf-2.
90
# AVR (extended) COFF requires stabs, plus an avr-objcopy run.
91
#DEBUG = stabs
92
DEBUG = dwarf-2
93
94
# List any extra directories to look for include files here.
95
#     Each directory must be seperated by a space.
96
EXTRAINCDIRS =
97
98
# List any extra directories to look for library files here.
99
100
EXTRA_LIBDIRS =
101
102
103
# Compiler flag to set the C Standard level.
104
# c89   - "ANSI" C
105
# gnu89 - c89 plus GCC extensions
106
# c99   - ISO C99 standard (not yet fully implemented)
107
# gnu99 - c99 plus GCC extensions
108
CSTANDARD = -std=gnu99
109
110
# Place -D or -U options for C here
111
RUN_MODE=ROM_RUN
112
CDEFS =  -D$(RUN_MODE)
113
114
# Place -D or -U options for ASM here
115
ADEFS =  -D$(RUN_MODE)
116
117
CDEFS += -D__WinARM__ -D__WINARMSUBMDL_$(SUBMDL)__
118
ADEFS += -D__WinARM__ -D__WINARMSUBMDL_$(SUBMDL)__
119
120
# Compiler flags.
121
122
ifeq ($(THUMB_MODE),YES)
123
THUMB    = -mthumb
124
THUMB_IW = -mthumb-interwork
125
else
126
THUMB    =
127
THUMB_IW =
128
endif
129
130
#  -g*:          generate debugging information
131
#  -O*:          optimization level
132
#  -f...:        tuning, see GCC manual and avr-libc documentation
133
#  -Wall...:     warning level
134
#  -Wa,...:      tell GCC to pass this to the assembler.
135
#    -adhlns...: create assembler listing
136
137
# Flags for C and C++ (arm-elf-gcc/arm-elf-g++)
138
CFLAGS = -g$(DEBUG)
139
CFLAGS += $(CDEFS) $(CINCS)
140
CFLAGS += $(OPT)
141
CFLAGS += -Wall -Wcast-align -Wimplicit
142
CFLAGS += -Wpointer-arith -Wswitch
143
CFLAGS += -ffunction-sections -fdata-sections
144
CFLAGS += -Wredundant-decls -Wreturn-type -Wshadow -Wunused
145
CFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS))
146
147
# flags only for C
148
CONLYFLAGS += -Wnested-externs
149
CONLYFLAGS += $(CSTANDARD)
150
151
ifneq ($(AT91LIBNOWARN),yes)
152
#AT91-lib warnings with:
153
CFLAGS += -Wcast-qual
154
CONLYFLAGS += -Wstrict-prototypes
155
#CONLYFLAGS += -Wmissing-declarations
156
#CONLYFLAGS += -Wmissing-prototypes
157
endif
158
159
# flags only for C++ (arm-elf-g++)
160
# CPPFLAGS = -fno-rtti -fno-exceptions
161
CPPFLAGS =
162
163
# Assembler flags.
164
165
#  -ahlns:     create listing
166
#  -g$(DEBUG): have the assembler create line number information
167
ASFLAGS = $(ADEFS) -Wa,-g$(DEBUG)
168
169
170
#Additional libraries.
171
172
# Extra libraries
173
#    Each library-name must be seperated by a space.
174
#    To add libxyz.a, libabc.a and libefsl.a:
175
#    EXTRA_LIBS = xyz abc efsl
176
#EXTRA_LIBS = efsl
177
EXTRA_LIBS =
178
179
#Support for newlibc-lpc (file: libnewlibc-lpc.a)
180
#NEWLIBLPC = -lnewlib-lpc
181
182
MATH_LIB = -lm
183
184
# CPLUSPLUS_LIB = -lstdc++
185
186
187
# Linker flags.
188
#  -Wl,...:     tell GCC to pass this to linker.
189
#    -Map:      create map file
190
#    --cref:    add cross reference to  map file
191
LDFLAGS = -nostartfiles -Wl,-Map=$(TARGET).map,--cref,--gc-sections
192
LDFLAGS += -lc
193
LDFLAGS += $(NEWLIBLPC) $(MATH_LIB)
194
LDFLAGS += -lc -lgcc
195
LDFLAGS += $(CPLUSPLUS_LIB)
196
LDFLAGS += $(patsubst %,-L%,$(EXTRA_LIBDIRS))
197
LDFLAGS += $(patsubst %,-l%,$(EXTRA_LIBS))
198
199
# Set Linker-Script Depending On Selected Memory and Controller
200
#LDFLAGS +=-T$(SUBMDL)-ROM.ld
201
LDFlAGS += -T2124_demo.cmd
202
203
204
# Define programs and commands.
205
SHELL = sh
206
CC = arm-elf-gcc
207
AR = arm-elf-ar
208
OBJCOPY = arm-elf-objcopy
209
OBJDUMP = arm-elf-objdump
210
SIZE = arm-elf-size
211
NM = arm-elf-nm
212
REMOVE = rm -f
213
REMOVEDIR = rm -f -r
214
COPY = cp
215
216
# Define Messages
217
# English
218
MSG_END = --------  end  --------
219
MSG_FLASH = Creating load file for Flash:
220
MSG_LST = Creating listing file
221
MSG_EXTENDED_LISTING = Creating Extended Listing:
222
MSG_SYMBOL_TABLE = Creating Symbol Table:
223
MSG_LINKING = Linking:
224
MSG_COMPILING = Compiling C:
225
MSG_COMPILING_ARM = "Compiling C (ARM-only):"
226
MSG_ASSEMBLING = Assembling:
227
MSG_ASSEMBLING_ARM = "Assembling (ARM-only):"
228
MSG_CLEANING = Cleaning project:
229
MSG_FORMATERROR = Can not handle output-format
230
MSG_LPC21_RESETREMINDER = You may have to bring the target in bootloader-mode now.
231
232
# Define all object files.
233
COBJ      = $(SRC:.c=.o)
234
AOBJ      = $(ASRC:.S=.o)
235
COBJARM   = $(SRCARM:.c=.o)
236
AOBJARM   = $(ASRCARM:.S=.o)
237
238
# Define all listing files.
239
LST = $(TARGET).lst $(ASRC:.S=.lst) $(ASRCARM:.S=.lst) $(SRC:.c=.lst) $(SRCARM:.c=.lst)
240
241
# Compiler flags to generate dependency files.
242
### GENDEPFLAGS = -Wp,-M,-MP,-MT,$(*F).o,-MF,.dep/$(@F).d
243
GENDEPFLAGS =
244
245
# Combine all necessary flags and optional flags.
246
# Add target processor to flags.
247
ALL_CFLAGS  = -mcpu=$(MCU) $(THUMB_IW) -I. $(CFLAGS) $(GENDEPFLAGS)
248
ALL_ASFLAGS = -mcpu=$(MCU) $(THUMB_IW) -I. -x assembler-with-cpp $(ASFLAGS)
249
250
251
# Default target.
252
all: version build size
253
254
ifeq ($(FORMAT),ihex)
255
build: elf hex lst sym
256
hex: $(TARGET).hex
257
IMGEXT=hex
258
else
259
ifeq ($(FORMAT),binary)
260
build: elf bin lst sym
261
bin: $(TARGET).bin
262
IMGEXT=bin
263
else
264
ifeq ($(FORMAT),both)
265
build: elf hex bin lst sym
266
hex: $(TARGET).hex
267
bin: $(TARGET).bin
268
else
269
$(error "$(MSG_FORMATERROR) $(FORMAT)")
270
endif
271
endif
272
endif
273
274
elf: $(TARGET).elf
275
lst: $(TARGET).lst
276
sym: $(TARGET).sym
277
278
279
# Display size of file.
280
ELFSIZE = $(SIZE) -A $(TARGET).elf
281
282
size:
283
  @if [ -f $(TARGET).elf ]; then $(ELFSIZE); fi
284
285
# Display compiler version information.
286
version :
287
  @$(CC) --version
288
289
# Create final output file (.hex) from ELF output file.
290
%.hex: %.elf
291
  @echo
292
  @echo $(MSG_FLASH) $@
293
  $(OBJCOPY) -O ihex $< $@
294
295
# Create final output file (.bin) from ELF output file.
296
%.bin: %.elf
297
  @echo
298
299
  $(OBJCOPY) -O binary $< $@
300
301
# Create extended listing file from ELF output file.
302
# testing: option -C
303
%.lst: %.elf
304
  @echo
305
  @echo $(MSG_EXTENDED_LISTING) $@
306
  $(OBJDUMP) -h -S -C $< > $@
307
308
309
# Create a symbol table from ELF output file.
310
%.sym: %.elf
311
  @echo
312
  @echo $(MSG_SYMBOL_TABLE) $@
313
  $(NM) -n $< > $@
314
315
316
# Link: create ELF output file from object files.
317
.SECONDARY : $(TARGET).elf
318
.PRECIOUS : $(AOBJARM) $(AOBJ) $(COBJARM) $(COBJ)
319
%.elf:  $(AOBJARM) $(AOBJ) $(COBJARM) $(COBJ)
320
  @echo
321
  @echo $(MSG_LINKING) $@
322
  $(CC) $(THUMB) $(ALL_CFLAGS) $(AOBJARM) $(AOBJ) $(COBJARM) $(COBJ) --output $@ $(LDFLAGS)
323
324
# Compile: create object files from C source files. ARM/Thumb
325
$(COBJ) : %.o : %.c
326
  @echo
327
  @echo $(MSG_COMPILING) $<
328
  $(CC) -c $(THUMB) $(ALL_CFLAGS) $(CONLYFLAGS) $< -o $@
329
330
# Compile: create object files from C source files. ARM-only
331
$(COBJARM) : %.o : %.c
332
  @echo
333
  @echo $(MSG_COMPILING_ARM) $<
334
  $(CC) -c $(ALL_CFLAGS) $(CONLYFLAGS) $< -o $@
335
336
# Compile: create assembler files from C source files. ARM/Thumb
337
## does not work - TODO - hints welcome
338
##$(COBJ) : %.s : %.c
339
##  $(CC) $(THUMB) -S $(ALL_CFLAGS) $< -o $@
340
341
342
# Assemble: create object files from assembler source files. ARM/Thumb
343
$(AOBJ) : %.o : %.S
344
  @echo
345
  @echo $(MSG_ASSEMBLING) $<
346
  $(CC) -c $(THUMB) $(ALL_ASFLAGS) $< -o $@
347
348
349
# Assemble: create object files from assembler source files. ARM-only
350
$(AOBJARM) : %.o : %.S
351
  @echo
352
  @echo $(MSG_ASSEMBLING_ARM) $<
353
  $(CC) -c $(ALL_ASFLAGS) $< -o $@
354
355
356
# Target: clean project.
357
clean: clean_list
358
359
360
clean_list :
361
  @echo
362
  @echo $(MSG_CLEANING)
363
  $(REMOVE) $(TARGET).hex
364
  $(REMOVE) $(TARGET).bin
365
  $(REMOVE) $(TARGET).obj
366
  $(REMOVE) $(TARGET).elf
367
  $(REMOVE) $(TARGET).map
368
369
  $(REMOVE) $(TARGET).a90
370
  $(REMOVE) $(TARGET).sym
371
  $(REMOVE) $(TARGET).lnk
372
  $(REMOVE) $(TARGET).lst
373
  $(REMOVE) $(COBJ)
374
  $(REMOVE) $(AOBJ)
375
  $(REMOVE) $(COBJARM)
376
  $(REMOVE) $(AOBJARM)
377
  $(REMOVE) $(LST)
378
  $(REMOVE) $(SRC:.c=.s)
379
#  $(REMOVE) $(SRC:.c=.d)
380
  $(REMOVE) $(SRCARM:.c=.s)
381
#  $(REMOVE) $(SRCARM:.c=.d)
382
#  $(REMOVEDIR) .dep | exit 0
383
384
385
# Include the dependency files.
386
#-include $(shell mkdir .dep 2>/dev/null) $(wildcard .dep/*)
387
388
389
# Listing of phony targets.
390
.PHONY : all begin finish end size gccversion \
391
build elf hex bin lss sym clean clean_list program
von Oliver (Guest)
It's probably not a problome in your makefile.
Somewhere a symbol "symbol_start" is referenced, but this is not defined
anywhere.
Check your linkerscript and the startupcode, (and the complete
application), to figure out, where "symbol_start" is used. Usually the
linker script and the startup code dependend on each other. if you take
them from different examples, you have to adapt them manually.
Oliver
